Question about Sharp AR-M276 Staple Cartridge 3Pack OEM 9,000 Staples - Staple-Cartridges-AR-M276
I want to set up scanning from a sharp AR-M276 Copier to an email address
  • 3 Answers
SOURCE: NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
Custom settings, List print, Print test page, NIC Page.
Posted on Jul 27, 2007
mickspaceNET
  • 115 Answers
SOURCE: Network Error on display
If you’re getting this on both machines, it is your network...
There a few possibilities...
1. SMTP / DNS Info. Is that correct? Your It can help with this?
go to the Nic page of the machine (IP Address in win explorer) , go to admin page, which the pass word should be sharp , look for the network settings. look at both the smtp info and the gateway and dns info.. Verify that it is correct.
2. Have you changed your Internet Service Provider?
For example, Comcast is making a habit of blocking port 25. Embarq DNS information is a mess, their mail relay is a real hassle.
3. E Mail server information changed? Does your server require authentication, is the Time out set correctly?
Posting the correct codes really help in resolving these issues
Below are a few of the codes...
CE 01 The network card is not installed or broken
CE 02 the specified mail server is server is not found.
CE 03 The specified server suspends response during Transmission of images.
Posted on Oct 23, 2008
SOURCE: Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Posted on Apr 20, 2009
SOURCE: Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Posted on May 20, 2009
  • 118 Answers
SOURCE: How do i change the IP address on the sharp ar 275
press printer button >special key then you can browse through arrow button check there you can see how to change IP address
Posted on Jul 19, 2009
How to clear u2-40 error for sharp ar m276
This is error for Error in MCU-CRUM chip communication. Probably because of developer unit has bad contact.
Try to reconnect developing unit and then turn on the copier. If problem persist call service!
Hope that helps!
Sep 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M276 m affiche maintenance requise code:U2-40,rien ne marche.je rallumer à plusieurs reprise ça ne marche pas.que faire?
it is IC conector problem.pull out the cartridge and put it into the copier again.if the problem still exists change toner cartridge.
Aug 15, 2010 | Sharp AR-5316 Advanced Digital Imager...
I got H4-00 problem in my AR -M276 Photocopy
Press # * C *, then enter 14 and press start, then 1 and start, then clear.
Jul 27, 2010 | Sharp AR-168S Copier
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
Scanning
yopu do all this on your computer program this machine does not have scan to email in the machine so you need an external program to achieve this.
Dec 04, 2008 | Sharp AR-168D Black and White Copier
AR-M350N Sharp Copier
Yes, it is possible. You need to use the software for your Sharp copier to scan the colored picture. Once you have scan it, you may use or send it to any email address.
Oct 21, 2008 | Sharp AR-M350N Copier
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp AR-M276 Staple Cartridge 3Pack OEM 9,000 Staples - Staple-Cartridges-AR-M276 Logo
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
