Question about Samsung SGH-i750
Cannot receive calls
While my phone was apparently on, i received several calls but nothing appeared on the screen,no missed calls nothing...the phone worked again after a reset but the problem occured again later on. Does anyone know how to solve this problem?
  • Anonymous Feb 27, 2008
    i just bought samsung SGH-i750 portable pc phone and problem i am having is that if someone called me i can't retrieve the missed called also my battery is strong anyone who can help should e-mail me on [email protected]
You maybe need to "turn on the phone", as they would call it. But actually, you just go to Start->Settings->System->Phone and it will ask you to turn on the phone. You just yes.
Posted on Aug 23, 2007
SOURCE:
I am getting several calls a day from the number 02 43455698. Yesterday I had 7 calls in an hour. I have caller ID so don't answer but if I dial 101 there is never a message just a missed call.
this number is on the service providers list of crank calls and is generated by a computer
It has been reported many times but it appears that nothing can be done
if you have a mobile you can block that number so you do not receive the call
if you have a landline phone call your service provider and ask that the number be blocked to your phone
Feb 28, 2017 | Cell Phones
How do you know if you have a voice mail message
Yes, the was bothering me for some time. I think the indicator is a little green light that blinks in the extreme upper left hand portion of the phone...not on screen, above it....but the blinking light may indicate a missed call or a voice mail is present.
Try this. Go into your phone icon, press and hold '1' and listen to any open messages. Delete each. Next go into your Call Log and delete all call history. Now exit.There should be no green light flashing in the upper left hand corner of phone. You have just cleared everything.
Next call your phone but hang up before leaving a message. Note the blinking green light in the upper left hand corner apparently indicating you missed a call. Go into your Call Log. It will say one missed call. Exit the call log and note that the blinking light is now off. You have acknowleged the call in the call log so the light goes off when you exit.
Call the phone again. This time leave a message. Note the blinking light again. Go into your call log again. Note the missed call. It would be nice if there was an icon or something HERE that indicates if this call left a voice message....but there does not appear to be. Exit again. This time note that the light continues to blink even though you entered the call log and acknowleged the call. I believe it continues to blink because you have a voice message. Exit.
Go into the call log again. Delete the missed call from the call hsitory. Exit. The light still blinks, I believe still indicating a voice message.
Go to your phone icone. Press '1' to check messages, delete the message and exit. The blinking is now gone.
So it appears a blinking green light indicates a missed call. If it still blinks after exiting the call log, you have a voice message.
If someone figures something else out let me know because this stinks!
May 28, 2014 | AT&T GoPhone Radiant
Missing Calls and Texts. Alarm Caput.
Cause:-
Call logging is not enabled for the Message list.
Ensure call logging is enabled from the Phone application Options menu.
1) From the Home screen, open the Phone application.
2) Display the menu and select Options.
3) Select Call Logging.
4) In the Show these call log types in message list field, select the type of call log to be displayed in the messages list.
5) Display the menu and select Save.
I hope I was able to help you.
Nov 23, 2009 | RIM BlackBerry Pearl 8100
Alerts give a single ring and do not display on screen.
To Do, Alarm and Incoming Messages give a single audio alert but to not display on the screen. The Snooze function does not work although it is selected. Missed calls do not display
May 05, 2009 | Nokia 3120 Cellular Phone
D900 motherboard or screen?
Well you should take it back and have them fix it the correct way
Sep 02, 2008 | Samsung SGH-D900 Cellular Phone
Blank screen
apparently you damaged your flex cable that connects the main board to the lcd - hence your calls work , but nothing on screen - to repair it costs - $25-40
http://horizonwirelessonline.com
Jan 23, 2008 | Motorola Mobility L6 Cellular Phone
Cant see any dispaly
it appears that your display has gone bad or there is a display connector problem. If you are tech savvy then open the phone carefully and on proper examination u will find that there is a connector for the display carefully take it off and replace it. Check if it works if not replace the display
Nov 13, 2007 | Nokia 6630 Cellular Phone
6630 sms problem
It appears that you have other programs running in the background and haven't been closed. To check this keep the menu button pressed for about 2-3 seconds and the phone will show the programs running in the background. If there are more than 1 close the others that's it.
also check the date and time on your phone and update it if it isn't current.
Nov 11, 2007 | Nokia 6630 Cellular Phone
Screen and Faceplate non-responsive
I have a similar problem and have had it almost since I got my phone. I have had my phone "repaired" but it still does it. The only advice I can offer you is that my phones screen eventually work again after a few days, so I would be interested to know if this is the same for you. Also others who have described similar problems have been advised it relates to a "strip problem", but I do not know what that is. Perhaps this means something that can help you.
Apr 18, 2007 | Motorola Mobility RAZR V3
Open Questions:
-\&;-TWITTER Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A x This Twitter USA phone number is ranked #2 out of 2 because 7,728 Twitter USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Twitter USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, Twitter USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Twitter USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Twitter USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Twitter USA Calling Twitter USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Twitter USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Twitter USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Twitter USA's phone numbers against each other. Contacting Twitter USA in General While I8OO8280294 is Twitter USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach Twitter USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Twitter USA.
Oct 16, 2019 | Twitter Computers & Internet
-\&;-TELUS Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A This Telus USA phone number is ranked #2 out of 2 because 7,728 Telus USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Telus USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, Telus USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Telus USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Telus USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Telus USA Calling Telus USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Telus USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Telus USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Telus USA's phone numbers against each other. Contacting Telus USA in General While I8OO8280294 is Telus USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach Telus USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Telus USA.
Oct 16, 2019 | Best Computers & Internet
See all Samsung SGH-i750 Questions
Samsung SGH-i750 Logo
46 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
