Question about Intermec EasyCoder PM4i Printer
Label not printing
Labels not printing dark enough.
    Problem Solver:
  • 14 Answers
Firstly, check your software settings, sometimes you need to reduce the print speed a bit, and turn the darkness up... if there is a knob for print head pressure adjustment, turn it up! i'd also clean the head and platen roller with isopropyl alcohol, failing all of the above, contact your media supplier and check that you have the correct media combination. hope this is of help to you, Markus.ps Failing that ...if you need a trained intermec engineer....... contact Precision Peripherals.... jrichards@printer-service.co.uk
Posted on Jul 03, 2009
  • Phanatic1029 Mar 27, 2012
    Do you know why or how printing a label would reset the darkness setting back to 0? I set it to 10 and print the test prints fine, turn the printer on/off multiple times and the darkness stays at 10 but when I print a label it goes back to 0 and the portions of the label are unlegable.
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
HI, our Zebra 4m+ is currently set to a Darkness of 30 as that seems to eb th eonly way it will print enough detail on the label. We have tried adjusting the pressure settings to no avail. Now we are...
Full resin ribbons tend to require higher darkness settins on all thermal printers.
It could be a mismatch between label and ribbon. This would need to be looked by your supplier.
May 25, 2011 | Zebra 105SL Thermal Label Printer
I have a Zebra s600 that is set to 30 darkness and the head is screwed down fairly tight. I can print this way but if the printing lightens up, I don't have any more adjustment. The barcode reader picks up...
0.print config label (printer off, press Cancel button and tur on printer, wait 5 secunds and relese button)
1.press the last button until the ligth set on Darkness (Darkness on),
2 press the 3rd button 10 times( darkness down from 30 to 20 (3rd button=less 2nd button=more),
3.press 2 times the last button untill the 3 leds flash(save)
4.turn printer off.
5.Press pouse button, turn printer on, still pressing for 8 secunds, and then release te button.
6.The printer go to print the test label, let run 3 or 5 labels, then pause.
If not happy, repeat steps 1 and 2 (less times 2 or 3 times at the time and save)
print configuration label again ans se if you happy.
If the printer still going to darkness 30, chek if you forgot to save or check the driver settings and change.
Last option Resect to Factory Defult (this drop darkness to +10)
Oct 29, 2010 | Zebra Stripe S600 Thermal Label Printer
The barcode cannot be printed on the direct label
Your description is not very specific but no printing can be the result of:
1. The darkness is not set high enough
2. The ribbon is loaded backwards
3. You are trying to do direct thermal printing (no ribbon) but the label stock is not direct thermal stock.
Maybe you can provide more details.
Hope this helps,
Jul 18, 2010 | Zebra Stripe S600 Thermal Label Printer
Not printing
If you send a format and the label advances but does not print, then it is possible that the darkness setting is not high enough for the label/ribbon combination. Depending on what software / printer driver you are using, many times the darkness setting in the software or driver will override what is in the printer. This makes it possible to have the test print work just fine but no printing when a label format is sent the printer.
If you are sending a format and nothing at all happens at the printer, then that is a communication issue. How are you connecting the PC to the printer ?
Apr 19, 2010 | Datamax I-4308 Thermal Label Printer
Label print too light
This could be caused by the darkness setting coming from the label software / printer driver. It's set too low and that setting will usually override the darkness setting in the printer. That's why test labels are fine.
Hope that helps.
Apr 08, 2010 | Datamax M-Class 4208 Thermal Label Printer
I am using a Monarch 9850. We do not print much with it - maybe 10 or 15 thousand misc sizes labels a year. It does not print dark enough. I am printing black ribbon. I have changed ribbons three or four...
I would suggest an update on your printers firmware after which it will perform a calibration procedure. please check here for for further guide on update information
Apr 08, 2010 | Paxar Monarch 9850 Thermal Printer
My Z4M Plus printer is not printing the label all the settings are fine no error. The ribbion shows the image but it doesnot print on the Label.
Two possiblities: 1. the darkness is not high enough for the ribbon/label combination. 2. the ribbon is on backwards. if the ribbon is on backwards, you will still see an impression on the ribbon but not on the label. This means all the ink transferred to the printhead which should then be cleaned.
The ink side of the ribbon needs to face down to the label to print so the easiest way to make sure which side has the ink is to use a label or piece of tape and touch it to the ribbon. If no ink comes up in the adhesive then that is the wrong side.
Hope that helps !
Apr 01, 2010 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
My lp 2844 will not print
Firstly is your label Thermal Direct?(DT)
To test quickly score your fingernail across the surface of the label, if it leaves a black mark then it is DT
If there is no mark then it is probablly Thermal Transfer(TT) and requires a ribbon, which you cannot use on the LP 2844, only on the TLP2844.
If you have DT labels then go into the printer driver via Printers & Faxes and the Printing preferences and change the darkness to level 7.
Try printing again.
If it works then cahnge the darkness again until you get a satisfactory print darkensss.
If it still does not print then change the darkness to maximum, does it print?
If not then I think you have a duff printer, return it to the company that supplied it for repair.
Any problems contact Lancer labels
Apr 05, 2009 | Zebra LP 2844-Z Thermal Label Printer
Intermec EasyCoder PM4i Printer Logo
415 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
