Question about KRK Kns-8400 Headphones - KNS8400
Krk kns 8400 serial number - KRK Kns-8400 Headphones - KNS8400
Dress Maker Model KNS Deluxe Zig Zag
If you are looking for a manual go here:
http://www.sewusa.com/
manuals - deluxe zigzag - kns
This machine was imported by several companies so a generic booklet was made. I have the same machine and the one the cover is the exact same one.
Nov 02, 2012 | Sewing Machines
I need to remove one power amp module from an older KRK Expose E8. The obvious screws have been removed but the module still feels firmly attached to the cabinet. Is there something that I am missing?
Hello
If you have unscrewed all the seating screws of the circuit board, pull out three knobs at the rear side [HF SHELF/SYSTEM LEVEL ADJUST/HF LEVE ADJUST] and rings screwed to the switches of LF Level adjust, and the screws of XLR socket. Amp with its seating frame wcan be pulled out.
For further details log on to
www.krksys.com/krk-studio-monitor-speakers/expose.html
OK.
Apr 12, 2011 | KRK E8B EXPOSE
My Serial Number Is Same So I want an Activation Cade
Please try with these few code. Hope one of them is helpful.
Adobe Acrobat 7.0 Professional
S/N: 1118-0410-9277-9328-2007-0400
Try these serial no for activation.
1118-1214-5103-7072-7168-6353
5338 - 7515 - 8016 - 8400 - 0685 - 4348 - 3818
6208 8987 3062 7443 1221
Activation nº
4289 - 8535 - 3811 - 1867 - 7153 - 1271 - 6560
Authorization Code:
0801 5752 0203 3694 0809
Feb 14, 2010 | Adobe Acrobat 7.0 Professional
I have a KRK Rokit Powered 5 studio monitor and the fuse blew out, so i replace the fuse with the spare they provide and ''bam'' blows again as soon as i turn on the monitor. i have had these for about 4...
Look for a failure in the power supply section. You will need electronic experience or someone who has that.
If the fuse is glass and blows silvery inside thia means a direct short inside. SUSPECT the input rectifier or filter capacitor(s).
Do testing with a 100 watt light bulb in series with the hot side of the power cord to avoid blowing fuses.
Oct 10, 2009 | Music
I need the key ganarater of cs2 9.0adobe photoshop
Key generators are illegal when used on licensed software.
Please purchase a legitimate copy.
Mar 07, 2009 | Adobe InDesign CS2 for PC
Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
a single male rca spliting into 2 male rca's ....a signal splitter
Oct 30, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
KRK Kns-8400 Headphones - KNS8400 Logo
198 people viewed this question
Top KRK Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a KRK Audio Player and Recorder Expert? Answer questions, earn points and help others
