Question about Sony KV-36XBR250 TV
Sony TV Won't Come On
I have a Sony KV-36XBR250 Tv, made in 2000. LAst time I trued to use the TV, the power "flashed" on, then it went dead. I cannot get it to do anything now, either from the remote or from the TV itself. I confirmed that there is power to the TV. ANy ideas?
  • 5 more comments
  • mark_j_salzb Jan 23, 2009
    NOTHING happens when I hit the "power" button on both the remote and the TV.
    It looks like the fuse is blown. I can't quite read the number on the fuse, though. Any idea what the fuse part number is? Looks like BUSS GDC on the glass part and T63AL 250V on the metal end, but when I google that, nothing shows up.
    THANKS. I'll let you know if it works.
  • mark_j_salzb Jan 26, 2009
    The 5A 250 V fuse solved the problem. THANKS!!! It saved me several hundred dollars for a service call for the TV. The SONY is designed well - it was easy to take the back off the TV to replace the fuse.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    5A 250 volt fuse would be fine to test TV and fuse would be available in local repair / part shop.
    If fuse blow off again, then TV has problem in Power supply section and requires qualified TV tech.
    Unplug TV from AC outlet and if you are comfortable to open back cover of TV then check fuse in power supply which might blow off. upon replacement of fuse, replug in AC and check.
    does standby light flash / blink in TV? if yes, how many times.
  • 10,594 Answers
Thats great, problem resolved.
Please rate solution as fixya ( 4 blue diamonds)
Thanks.
Posted on Jan 26, 2009
TV SONY Trinitron XBR KV-36XBR250
Check whether the filament of CRT glow or not. If not, check all the solder terminals at the CRT base card. If it glows, check all the voltages at the video output card, said above. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Jan 01, 2014 | Sony KV-36XBR250 TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony Trinitron WEGA KV-XJ29M50 29" TV - Dead, LED flashes 2 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-XJ29M50 29" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Blinking picture
TV Repairman came out today to look at my Sony KV-36XBR250 today with the exact same problem - he was able to adjust the settings through the service menu, but said it was a temporary fix only.
The picture tube is going and the Sony circuitry has a "video mute" that it uses when it senses the tube is not warmed up enough. The degraded state of the tube causes the blinking on and off as the signal from the tube wavers.
He ballpark estimated the tube replacement cost well above the price for replacing the set with a 37" LCD, so it's going to the dump...
Mar 02, 2008 | Sony KV-36XBR250 TV
Sony KV-36XBR250 TV Logo
326 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
