Question about Frigidaire GLWS1233A Top Load Washer
Washing Machine don't spin.
I have a Model GLWS12334S1 Frigidaire washing machine, the problem i am having is that when it gets to spin cicle, it stop, leaving the load full of water. Is there a solution for this so i can do it myself??? I will appreciate your suggestions. Thanks.
Great answer not clicking therefore it must be the switch. Will let you know when I change it TKS
Posted on Jan 29, 2009
  • 12 Answers
Hi Mambo; Your problem is a fairly common one. The lid switch has gone bad. To test this, open the lid and locate the switch. It will be a small hole that has a plastic piece in it. Use a pencil and push down on it. If you hear, or feel a 'click' then you may have another problem. If you don't hear, or feel a 'click' then the switch is bad and will need replacement. Replacement will require some advanced knowledge of washing machines and the ability to use a box of tools proficiently. Best regards; HELP2DIY
Posted on Jul 10, 2007
SOURCE:
My Frigidaire model FTF2140ES will not spin or drain no matter what settings I put it on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Front loading model #FTFB4000FS1 is not draining....have to run the drain/spin a second time to get the water out....where i s the filter?
heatman101
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
My frigidaire front load washer Model #GLTF2940E will not spin out
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
My frigidaire washer model # fws545rfs0 wont drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 21, 2011 | Frigidaire Washing Machines
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
Will not spin dry clothes.
My washing machine doesn't work, alarm on spin function
Mar 13, 2009 | Frigidaire Washing Machines
Frigidaire Washing Machine Model 975FS2
all wsher have bearings which hold the drum centrally if these are worn than the machine will make a noise and get louder on spin and will only get worse sometimes cheaper to replace washer than it is to fix your bearings sorry m8
Aug 11, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
128 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
