Question about Cellet Radio Communications
CELLET EB100 Bluetooth - Cellet Radio Communications
Pse help need assistance wth change ob bis password im am active at moment by I changed sim card with son and it has upset my setting need to reset password I have doesn't want to work have cn
Just ask your son for the password. You cannot just swap out the sym cards between you and expect it to work. You should have gotten a NEW symcard for each and then set them up new.
Dec 01, 2014 | Cellet Blackberry T-mobile Curve 9360...
Cellet bluetooth EB100 passkey
Most bluetooth devices use 0000 as a pass code
Feb 17, 2014 | Radio Communications
How do you change the language on the cellet
I cant figure it out either.. I'm about to use a hammer on this chinese piece of garbage
Nov 21, 2013 | Cellet Radio Communications
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
Bloacd my mobail memory card pliease solaved my provlam
Take the phone to nokia care shop so that they can unblock it for you.
Jan 24, 2011 | Cellet MicroSD 2GB Memory Card for Nokia...
The question is not clear enough, it will be much better if you can tell what precisely is the problem with the cellet professional retractable car charger. If you need details about the charger, i will be glad to offer assistance to you on that.
Jan 08, 2011 | Cellet Professional Retractable Car...
Radio Communications Logo
158 people viewed this question
Top Cellet Radio Communications Experts
Rigger
sandrasteven
Are you a Cellet Radio Communication Expert? Answer questions, earn points and help others
