Question about Samsung Qx410-s02 - Intel Core I5 - 640gb Hdd - 4gb Ram - Nvidia Geforce 310m
Usb port damaged on Samsung qx410-S02 repairable?
There is only one USB port on this model notebook and something has happened to damage it and nothing works in it. The computer works just fine otherwise. Do you know if this can be replaced or is it native on the motherboard?
SOURCE: USB port doesn´t work...
You will have to reinstall the usb drivers again from http://www.samsungpc.com/products/x05/x05_supporteddrivers/x05_supporteddrivers.htm
Posted on Oct 30, 2008
  • 1214 Answers
SOURCE: error code 19 - Device MANAGER - USB devices
What OS are you running? XP, Vista, 7, etc? In Control Panel where you see the yellow exclamation mark, right click and select Update Driver. When it asks where to find the driver, tell it to search the internet.
If it does not update, then go to the Samsung website to locate the drivers for your computer and OS.
Posted on Dec 10, 2009
SOURCE: NP NC-10 USB Stopped
this works like 99 outa a hundered.Simply Remove and reinstall all USB controllersTo remove and reinstall all USB controllers, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
  2. Click the Hardware tab.
  3. Click the Device Manager button.
  4. Expand Universal Serial Bus controllers.
  5. Right-click every device under the Universal Serial Bus controllersnode, and then click Uninstall to remove them one at a time.
  6. Restart the computer, and "Windows" will then automatically reinstall the USB controllers.
  7. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Remember with USB devices. FIRST, install software/drivers, then insert USB device SECOND.
Posted on Jan 25, 2010
  • 76 Answers
SOURCE: both usb ports does not work samaung x05
You need to reinstall your usb driver from Samsungs website.
Posted on Feb 03, 2010
  • 104 Answers
SOURCE: I HAVE A SAMSUNG N148
Yes most laptop screens can be replaced. Check with your local computer repair centers and see if they replace them. They are not to hard to replace but do require a person who knows what they are doing and what to look for. My place of work does fix them but we are located in Minnesota and it would require us getting the laptop and ordering the correct screen and then replacing it and shipping it back. Which could cost more then your local computer repair center to do.
Best of luck..
Have a Happy and Safe Holidays..
Posted on Dec 01, 2010
How to disassemble the Samsung NP-QX410-J01US to repair a cracked LCD Screen.
I highly recommend not opening your laptop to avoid further damaging it and voiding your warrantee.
Instead, call Samsung for help at1-800-SAMSUNG
Mar 07, 2011 | Samsung Laptop / Intel Core i5 Processor /...
I am trying to hook up a new printer HP Deskjet 1050 J410 Series and none of my usb ports seem to be working. Do these ports manfunction due to age?
yes, unfortuantely they do wear out (in/out connecting) ..thats why i always suggest using a USB hub (retails for about $10-$15 or less) -- plug it into one USB port and leave it (if its a desktop, dont try this with notebook or you will forget its there and cause damage while moving it around, from one place to another)
-try blowing out the dust from the inside USB connection of your computer , try it again -- but buy a USB hub first ,, youc ant go wrong having this around
is it a desktop ? if so , buy a new USB card and replace the old one
if its a notebook -- bad news , you need to spend money to replace the USB ports or buy another mainboard
i hate to see this happen --
what model & Mfg is your computer ?
Oct 16, 2010 | HP Pavilion dv1000 Notebook
Shows overcurrent on usb ports will not reset.
There is no reset. This issue can be attributed to two main causes.
1. Poor quality USB devices that have an internal short or place too much of a current demand on the USB electrical system. This issue may not manifest itself at first but with prolonged use of a bad USB device, damage can occur to the USB device and the internal USB controller. The damage is not reversable.
2. The USB controller on the motherboard is failing, or has been damaged.
As this controller is built in to the motherboard, there is not an easy way to repair the issue without help of the manufacturer or authorized repair center. Check with the manufacturer to see if this is frequent issue with this model, as there may be a technical bulletin posted about the issue. Like recalls with automobiles, the manufacturer may fix the issue free of charge.
Feb 24, 2010 | Toshiba Satellite A75-S211 Notebook
Usb damage
It wouldn't hurt to be honest about what happened with the service plan provider and see what they say. It would be a shame to have to replace your computer over a broken USB port. You can always purchase a USB hub which plugs into one USB port and supplies you with two or more USB ports.
Good Luck,
NOLA Tech
Jan 28, 2010 | Toshiba Satellite L305-S5894 Notebook
One of my Acer Aspire USB port will not let me
It is most likely that the Port has been damaged by having the wrong cable plugged into it. If one Port is still working, there is nothing wrong with the Computer.
With a Flash light, look inside the Port to see if any of the Contact Points are bent or damaged. If they are, there is only a slight chance that the Port Can be Repaired.
It will probably be cheaper to buy a 4 Port USB Hub and use the one Port with it.
Good Luck!
Dec 22, 2009 | Acer Aspire One PC Notebook
Samsung i70 problem
Yes, we had few situation with different digital cameras and professinal camcorders damaged in I/O port board due to power surge type damage. It is rare but depending on design of circuitry combination with laptop system. Due to the current present on usb port it is important to turn the camera off before unplugging the camera or any electronic devices. Remedy for the damage requires repair by technician. -James
Mar 30, 2009 | Samsung i70 Digital Camera
Dell inspiron 4000 loose usb port
DONT PLAY WITH YOU LAPTOP
GO TO YOUR NEAREST DEALER OTHERWISE YOU MAY DAMAGE MORE THING AND WILL LEAD TO MORE LOSS
Dec 13, 2008 | Dell Inspiron 4000 Notebook
Toshiba satellite USB port is damaged
If  the usb port is at the front side of the c.p.u then it can be replaced ,but if the usb port of the motherboard is damaged then you have to take it to any repairing centre and fix it for you......because it has to be replaced with any damaged motherboard usb port....Please don't do it yourself..
Sep 15, 2008 | Computers & Internet
Samsung Qx410-s02 - Intel Core I5 - 640gb Hdd - 4gb Ram - Nvidia Geforce 310m Logo
74 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
