Question about Canon PowerShot G9 Digital Camera
Recorded video segment plays back in fast motion. How do i reset
To actual speed
  • 4 Answers
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recordings.
Posted on Feb 04, 2009
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
My g9 was playing video clips very fast. i changed the setting back to "standard" and can record/play new videos correctly; however, the video clip that i previously recorded before i changed the setting...
I believe the setting you changed set the RECORD method, not playback. The video is recorded that way. There are some Video software out there that can rerecord a video at a slower pace, but do you want to spend the money? Try Ulead.com for a low cost program.
Apr 17, 2010 | Canon PowerShot G9 Digital Camera
Playback is too fast using Pinnacle Quick start version 10
This sounds like a Frames per second setting issue.
Just a guess, but you recorded at 15 FPS & the player is regurgitating at 24 (or 30) fps.
Sep 04, 2009 | Pinnacle Dazzle Video Creator Platinum...
Viewing my videos
i have good and bad news for you guys. the bad news is that you'll never beable to see those videos in the normal time frame again. but the good news is that there's nothing wrong with your camera. try turning the sd1100 on again in video mode. then press on the function/set button. now just set the capture mode back to standard. you've had it in time lapse. if this doesnt help, then iono.... lol good luck!
Mar 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
HP Pavilion dv9000 Web-cam problem!
HP issued the following:
Webcam Fast Recording Patch Release Date: 2007-05-17 Version: 1.00 A
s.gif Description
This package provides a patch for the Webcam for the supported notebook models and operating systems.
PURPOSE: Routine
Fixes
Fixes fast recording issue that occurs with the Webcam in Low Light mode.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-51291-1&jumpid=reg_R1002_USEN
sp35930
Dec 31, 2008 | HP Pavilion DV9260 Notebook
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Dec 04, 2008 | Electronics - Others
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
Canon PowerShot G9 Digital Camera Logo
432 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
