Question about Dometic Sealand 500 Plus Series Toilets
Troubleshoot SeaLand / Dometic 341549 Floor Flange Seal
Floor door does not close
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: Dometic RV refrig model NDR1292 seal on right door
Here's a link to number to call for info on replacement parts available.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Spare-Parts/
Posted on May 27, 2010
Garage door is sticking after being closed a few hours
Spray the bottom seal and the side seals with silicone spray.
Oct 19, 2017 | Cars & Trucks
How do I replace an oven door seal?
Piece of cake. Use pliers and pull on the small metal clips that hold the old seal on the door. Now simply press the clips on the new door seal into the same holes. The ends of the door seal should point to the floor when the door is closed.
Sep 28, 2015 | Kitchen Ranges
Dish washer spills suds on floor
Sounds like door seal. The rubber seal ends at the bottom of both sides. examine the ends to see if they look the same. some have a plastic insert. it may fallen out. cheap part to order.
Apr 14, 2014 | Whirlpool Gold WDT910SAYE Fully Integrated...
Flush ball sticking dometic toilet
Actually, it's the flush valve that's not closing. The ball operates the valve. In some cases the valve needs to be replaced; in others, the ball has absorbed water and is unable to close the valve completely.
Jan 14, 2013 | Dometic Sealand 500 Plus Series Toilets
Frigidaire refrigerator side by side model FRS26ZTH water on floor of freezer
pull it out from wall there is a tube that runs down to drip pan under neath also check door seal by closing door and sliding acard between seal and unit if loose or gap it will make unit sweat
Jul 13, 2012 | Frigidaire Refrigerators
Rain water filling up floor board on driver's side of 05 Chrysler 300 while sitting in driveway; appears to be coming through door. Could it be a floor plug missing and how would the would water...
Most newer cars don't have drain plugs in the floor. So it must either be your window does not close tightly or the rubber seal is completely gone around the lower door.
Are you getting enough rain that it reaches the floor board of your car?
Jun 28, 2011 | 2005 Chrysler 300
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
Kohller Rialto toilet, can not get toilet to seat properly, leaks from bottom. Tried 3 different wax seals and it still leaks. Toilet was purchased online from Home Depot, and cannot return to store. Same...
If you tried regular sized wax rings and they failed to seal, try using a double thickness wax ring, maybe the space between the floor flange and the toilet exceeds a regular wax ring size. If the floor has been re-tiled and the floor flange was not adjusted this could be your problem, anyhow good luck!
Jan 24, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet on uneven floor
I believe that I qualify... over 300 toilets installed in the past 15 months!!
I would go with the wax rings... but I would press the ring into the base of the toilet before installing the toilet....that way you are sure to have a good seal to the toilet....
If you actually read the directions, the manufacturer will tell you to press the wax ring onto the toilet....then install it onto the floor drain.
I guess that a PLAIN wax ring placed on the floor drain (since it is recessed) before placing the rubber-sleeve equipped ringed toiled is a good safety measure... I have done that an it work about 37 times out of 40.
Good question - BTW.. and well worded. THANKS for being specific and precise!!
Dec 31, 2009 | Jacuzzi BK37959 White Era?? Two-Piece...
Dometic Sealand 500 Plus Series Toilets Logo
49 people viewed this question
Top Dometic Home Experts
john h
Tom Chichester
Are you a Dometic Home Expert? Answer questions, earn points and help others
