Question about Sewing Machines
How do I thread brother E20 34A - Sewing Machines
I need a threading guide for my Brother Lock 935D. Help, please!!
Here is your manual
http://www.brother-usa.com/VirData/Content/en-US%5CHAD%5CConsumer%5CUsersManual%5CUM_925D_MULTI_1387.PDF
and a quick step video of how to thread it.
How to thread the Brother 1034d serger So Sew Easy
Nov 13, 2016 | Brother Sewing Machines
How to thread a brother xl 2230
Do you need the directions for threading the upper thread or the bobbin? For the top thread, place the spool on the pin (pull it up if needed). Then raise the presser foot with the lever and the needle (with the balance wheel on the side) to their highest point. Now work from the right to the left. Hook the thread on the rear thread guide and bring the thread forward and down to the front thread guide. Bring the thread up and pass it through the Take-Up lever. Bring the thread up and back down so that it falls into the slot. Bring the thread down and pull it behind the guide above the needle. Then thread the needle from front to back. If you have put in the filled bobbin, hold onto the thread and use the balance wheel to bring the needle down and back up. Use the upper thread to pull up the bobbin thread and pull several inches of the thread to the back of the machine.
Brother has the manuals and quick set-up guide on the product support page: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=XL2230#.VRHrpaSFr3g . The quick setup guide, http://www.brother-usa.com/VirData/Content/en-US%5CHAD%5CConsumer%5CQuickSetupGuide%5CQSG_XL_2230_EN_3166.pdf , has very good pictures of threading the machine.
I hope this helps.
Mar 24, 2015 | Brother Sewing Machines
How to thread a serger model 934d made from brother it has 4 thread to do
You can look at youtube.com and see various sergers being threaded, also Brother at www.brother-usa.com, and www.singerco.com is quite helpful for threading a serger. All sergers pretty much thread the same way, remember always thread the 2nd from the right first. You can download your manual for free at the Brother site and enlarge the diagrams. Just take your time, it took me almost an hour to finally get it , now I can thread any machine without any problems. At first, I was very intimidated, but you will get it, really.
Mar 20, 2011 | Sewing Machines
I lost the manual to my Brother Homelock 920D serger. I want to know how to thread and use it.
i need information on threading a 920D brothers serger, on paper so i can take it to my machine to thread
Mar 04, 2009 | Brother Lay-In Thread Serger Mechanical...
Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Feb 22, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
