Question about Samsung LN-S4041D 40 in. LCD HDTV
How to turn off overscan on samsung - Samsung LN-S4041D 40 in. LCD HDTV
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How do I enter the service menu on an Emerson EWF2004 CRT Television? (Pictures of the OVERSCAN ISSUE will be provided if needed.)
Older sets had vertical and horizontal size controls. If you have the horizontal size control, turning it counterclockwise will reduce the size of the picture horizontally and reduce the overscan.
Feb 25, 2016 | Emerson EWF2004 20" TV
My tv scren has been shrink, how to return it to the regular size. thanks
Try:
Main Menu - Picture - Screen Settings - 16.9 Overscan - ON
This mode displays the image for 16.9 aspect and when on enlarges the image to hide the edge of the image.
Good luck.
Sep 26, 2014 | Samsung Televison & Video
White stripe on screen
Unfortunately it seems that each time I turn the tv on and off it resets the screen position and I have to adjust it each time.
I would assume that my set would remember the settings.
Use Picture Size, not Picture fit. Set it to 16:9, instead of Fit To Screen. There's a handy button the the remote for this: P-Size. And the setting sticks between shut-offs.
What you are seeing is called "overscan", extra information that most broadcast stations send, because most old TV's were set to zoom-in/crop the signal they received. So.. with new TVs, like your Samsung, you get the choice between size "Fit to Screen" which is 1-to-1, for pixel-accurate inputs like Blu-Ray and DVD, and size "16:9" which is really "support for overscan", for old, less precise signals like broadcast.
Mustang Parts.
May 28, 2012 | Samsung Televison & Video
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
I have a samsung series 5 530 lcd. The picture is to big for the screen. I've tried everything in the manuel. help
Also, Check the picture menus for a pixel-to-pixel or 1-to-1 mode. This allows you to watch an HD signal with no overscan.
Jan 10, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
Picture is much too big
try the P-size button on the remote control
Jul 13, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
Samsung LN-S4041D 40 in. LCD HDTV Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
