Question about Hitachi 53UDX10B 53" Rear Projection Television
After i power it on, there is no pictures, no sounds too.
There is no pictures, no sounds after I powered it on. The signal is fine because I can watch another TV which shares the same DirectTV cable.
  • Minghua Zhang Jul 09, 2007
    the red light come on. but i do not hear any thing. I have not unplugged and plugged the set back in.
    Scholar:
  • 150 Answers
Does the red light come on? Do you hear a relay click, Have you unplugged and plugged the set back in? Short of opening the set up you probably have a power supply/deflection issue and will require a tv technician.
Posted on Jul 08, 2007
SOURCE:
We have a Panasonic Plasma TV and are experiencing TV signal issues when our Bose sound system is turned on. Is ther anything we can do to improve the signal when the Bose is on (signal fine when we t
Move the insulated cables for the bose away from the cables to the tv. Or go buy monster cables for the TV so there wont be interference. Sounds like power cables are interupting the picture.
Sep 20, 2012 | Panasonic Televison & Video
NO picture, but sound, picture is not distorted
Try changing channels. Power light is on, then it means there is power coming in, but no video signal is being received (audio signal is good). Try this: turn off the TV, take out the power cable out from the power socket, wait for 30 seconds, then plug it back in, and turn it on. It should work fine. But if not, then there might be a problem inside the TV itself. Go see a local TV technician.
Nov 08, 2009 | Televison & Video
I share a TV antenna with my neighbour. there are three splitters in the line - one to give an output to a next door bedroom TV, a second gives a signal to their lounge TV with th other leg continuing to...
I suspect there is a Mast Head Amplifier to supply enough signal to split so many ways and the power supply is powered from the power socket supplying the neighbours TV. Switch it off and no/poor signal.
Mar 21, 2017 | Televison & Video
No sound or picture but menu comes up
Check video source like DVD Player has power, check connecting cords, cable connections etc.
when TV gives menu on screen that means TV is fine and problem could be hooked video signal items.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
Monitor made a popping sound and went blank. no computer or tv signal coming through.
Sounds like a Power Supply comcponent failure in the high voltage panel supply circuit.
Backlight power seems to be ok.
Can only suggest obtaining repair quotations vs. Replacement purchase?
Oct 02, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
RCA 32" 1996 COLOR TRAC PLUS
Hello neall,
It sounds like you may have a power supply problem- (HV Power supply). I must ask if you have sound or not? If you have sound it is the HV supply only if you do not have sound the Low Volt power supply and possibly the HV power supply/Horizontal section has a problem. I would suggest that you take the TV to a qualified TV repair shop.
I hope this helps,
Thank You,
Shuttle83
Mar 18, 2008 | RCA F32632SB 32" TV
Samsung HCL4715W will not power on
At five years old, I doubt it will be worth replacing the power supply , a picture tube or two and possible the signal board. Cut your loses and get a new set.
Aug 25, 2007 | Samsung HCL4715W 47" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
