Question about Nikon D3100 Digital Camera
D3100 Nikon has an hour glass flashing
It says the disk is bad
2 Suggested Answers
  • 102366 Answers
SOURCE: setting dpi on my nikon d3100
DPI (dots per inch) is an output specification and is irrelevant to the camera. The camera puts a value into the field simply because it has to put something there. The DPI is set by the printing program when it prints a picture. A picture printed at 4x6 will obviously have more dots per inch than the same picture printed at 8x10.
Posted on Nov 30, 2012
Replaced the MK5065GSX hard drive used the recovery disks but 'no bootable drive' message displayed.
no PC stated
no OS stated
no source of recovery disks stated (HP, MS or crack.org)
or home made?DVD-R or CD-R?
the answer is all you said and more.
lots more.
bad disks wrong disks
bad CD drive
bad HDD drive.
or if laptop then main battery is bad (bigone) and overloads it.
why not boot to live linux disk (optical media)
UBUNTU, 16, FREE, BOOT IT AND HIT TRY ME.
See if PC runs ok.
then if that works run DISKtest during the above demo try me.
if that passes we we are at
bad media install disk you have (no os stated or class of media)
bad cd/dvd drive.
Jan 05, 2018 | HP Computers & Internet
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
My computer HDD have bad sactors please help to remove this on
When a hard disk has bad sectors, these sectors can be fixed by running check disk. This is a temporary fix as the hard disk is nearly worn out and it will get more bad sectors and evenually the hard disk will fail completely.
Bad sectors occur when the magnetic oxide on the disk platters is worn out and data cannot be written or read from these sectors.
To run check disk click Start - My Computer - right click on C Drive and click on Properties - click on Tools tab - then Check Now in Error Checking
I suggest once this has been done, you back up your data and purchase a new hard disk ready to install Windows etc. when the hard disk fails completely. You may want to install a new hard drive before the old hard drive fails completely.
Aug 21, 2010 | Western Digital Caviar SE WD1600AAJS 160...
CyberHome DVD 1600 won't record to Sony disk
I believe the recorder is bad, it should be able to accept all brands and types of disks. You might want to try another brand and type of disk just to make sure, if it does not work, the recorder is bad. Good luck to you!
Jan 03, 2010 | Cyberhome DVR 1600 DVD Recorder
Why does it read bad disk? i've tried two disks, that work perfectly on another DVD player. But reads as Bad disk on the GPX D2816
its the disk laser sensor is to sensetive that why it canot reads with an ordinary disk or a pirated disk or a disk that has a small scratch.
Nov 07, 2009 | GPX D2816 DVD Player
Won't play any disk, says "bad disk" after being stuck on "loading"
You have a dirty / defective laser , motor or cable. Only when opened can the problem really be diagnosed.
May 12, 2009 | Televison & Video
Lenovo T61error 2100: HDD0(hard disk drive)
To all users with: lenovo T61error 2100: HDD0(hard disk drive),
Possible cause:
  1. Corrupted hard disk logical sectror/hard disk logical error (bad format).
  2. Hard disk connector not well in place.
  3. Hard disk broken, physical fault.
Solutions:
  1. Format hard disk and reinstall system using a Windows setup CD.
  2. If that does not work the Hard disk must be removed to check thge connector, and to test the hard disk on a different computer.
  3. If the hard disk is bad , it must be replaced, and windows reinstalled repeating step one.
Nov 25, 2008 | Lenovo ThinkPad T61 Notebook
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
I am unable to use an image from the disc. The prompt tells me to install disc 2 but does not recognizes it. This is a new computer for me , therefore this should not be happening.
Then you either have a bad CD/DVD disk drive, or the disk itself is bad. Try a bunch of other disks and see if you can make the problem happen again if so, then call for warranty replacement of the disk drive (free). If you can't it is most likely the disk that is bad and call for warranty replacement of the disks (also free).
Jul 10, 2008 | Computers & Internet
Check bad sectors in hard drive
pankaj you can run scan disk if using 98, schedule the scan disk if using xp. it will scan the disk and  will give you full details about surface of disk
Oct 29, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Nikon D3100 Digital Camera Logo
56 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
