Question about iRobot 5800 Scooba Vacuum
Scooba in diagnostic mode
According to iRobot support, my Scooba is in a diagnostic mode. All lights are on and it goes up and down the acustic scale. They tell me this was caused by the power and clean button pushed simultaneously. Further, support tells me this mode is for iRobot engineers and that there is no way to get it out. I paid $500 for this thing new and cannot believe that Engineering is so stupid. Does anyone know how to get my Scooba out of diagnostic mode?
  • 9 more comments
  • karen_hall56 Jan 23, 2009
    To Ciraldo52. Sorry, it didn't work. Does anyone else have a possible solution?
    I have already left it unplugged overnight and that didn't help either.
    Abhishek33, all lights come on in sequence beginning with SERVICE then going through the last three. Pushing either light just runs it throught the sequence again. I can hold down the power button to turn off, but when I press power or clean it again goes throught the sequence.
    I was encouraged by the Wiz that suggested I clean the data stuff. Did, but unfortunately its still all lights. The good news is the Scooba is no worse off. Would you Wizzes keep trying. Right now I'm open for any suggestion-almost.
    Ginko, I don't want it in diagnostic mode. I have already removed battery and hoping to reset. Still no luck
    Rylee, I have checked these things. Thanks but still no Oscar. Please fellows and gals, keep trying.
    Did the thing with the bumper and unplugged. No go. I haven't given up, don't you.
  • karen_hall56 Jan 25, 2009
    This didn't do it either. The Scooba is still in Diagnostic mode
    askme, I don't feel confortable fooling around with the circuit boards. How much would it cost to have it repaired (ballpark figure). Thanks
  • Anonymous Mar 16, 2014
    iRobot Scooba backs up real fast, shut down, and repeat
  • 10,515 Answers
This is a common issue :)
his morning, I turned on my Scooba and it started beeping a scale of tones and blinking all its lights in sequence. After an hour or so of resetting, cleaning, disassembling, researching, and scratching my head, I stumbled across the solution on Roomba Review. But, for me at least, it was even easier than all of that. I don't have any of my own pictures for this procedure, but it's pretty straight forward.
  • Remove the battery and power.
  • Remove the two screws holding the bumper shell in place and remove it.
  • Carefully peel up the sticker with the control buttons on it. This sticker is actually the control panel. There is a data cable attached to it just below the "Clean" button. Be careful not to break it!
  • Clean the surface under the sticker with some isopropyl alcohol. (I didn't actually have to do this, but I'm sure it doesn't hurt.)
  • Gently replace the "sticker" (i.e. control panel) and make sure it's completely flat.
  • Check to see if it works again. If not, repeat.
  • Replace the bumper shell and screws....
thnx.
Posted on Jan 25, 2009
  • taran_2005
    taran_2005 Jan 25, 2009
    If the issue wld not resolve :(
    You can do a search for scooba stuck in test mode and come up with several similar issues involving the Scooba control panel and the button contacts. The contacts or communication tether/cable are what fail, moisture can be a contributing factor.
    A few options for you are to disassemble the scooba down to the control panel and either replace it or if you do not feel comfortable with doing the repairs you can ship it in to us to do the repair work for you. Either option will cost less than a replacement and if the repair costs through us exceed our recommended repair budget of $125 then you will have the option to trade it in.
    http://www.roombaexchange.com
    thnx.
    Master:
  • 416 Answers
If it is not on a warranty there few options for you are to disassemble it down to the control panel and either replace it or if you do not feel comfortable with doing the repairs you can ship to do the repair work for you. You can buy parts or trade it here
http://www.roombaexchange.com/proddetail.php?prod=903492&cat=40
But might be the "Clean" button just stuck on because of water damage to the button contacts. Try to pull it. Or you will need to disassemble the control panel and carefully seperate the mylar sheets that make up the contact using a box cutter. After that use isopropyl alcohol to clean the contacts
But it is only in case if you can do it.
And dont forget TO UNPLUG THE DIVICE FOM POWER OUTLET
Good Luck
Posted on Jan 24, 2009
    Sergeant:
  • 378 Answers
Remove the battery and let it be in a rest for 2 mins.then reinsert battery.this will reset and get it back to work
Posted on Jan 23, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Remove Scooba's tank by pushing down on the metal carrying handle and then lift up. Make sure there is a proper amount of cleaning solution in the "Clean" tank.
Once you have verified the fluid level in the "Clean" tank, you can test the following:
Check Scooba's pump -
With the tank still removed, press the Power button and then the "Clean" button.
  • If the pump makes a "whirring" or squirting sound, this indicates that the pump is turning. However, the pump valve could be blocked with debris. Using a turkey baster, straw, or sports bottle, force air or water through Scooba’s solution valve. Confirm that the baster, straw, or sports bottle fits snugly over Scooba’s solution valve and push the air or water through the system at least three times. Replace the tank and try re-starting Scooba.
  • If the pump does not make a "whirring" sound, or this problem occurs in the midst of a cleaning cycle, and the robot isn’t in drying mode (blinking Clean light), the pump may have stopped turning. Using the flat of your hand, strike the robot near the charging port to try to restart the pump.
If the pump is turning, but Scooba still does not put down solution:
  • Check that the battery is installed correctly and that the yellow tabs are inside the guide-holes on the chassis. If the battery is not inserted properly it can prevent the tank from seating properly in the robot.
  • Check that the stainless steel filter is properly seated.
  • Next, check that the vacuum port flow tube is installed properly.
  • Once you have checked the port seals, place the tank back into Scooba's receiver and latch it back into place by pressing gently down. (If you must press with a lot of force, there may be an obstruction between the tank the Scooba's chassis.)
Thanks
Rylee
    Brigadier General:
  • 5,158 Answers
Unplug it completely from any power for about a half hour and turn it back on... see if that fixes the issue
Robert
  • Roberta Smith
    Roberta Smith Jan 23, 2009
  • rntolaw Jan 02, 2011
    THIS worked!!! thanks so much! The worst part was removing the darn screws! Perfect! You saved me so much!
    Novelist:
  • 88 Answers
Did you try pressing both button again ?
  • 19,396 Answers
If there is no service code, you just have to remove the battery to reset the scooba.
Check here the service codes.
  • Ginko
    Ginko Jan 25, 2009
    Ring the Phone number listed on the owner manual to get a quote.
    Scholar:
  • 140 Answers
Try removing and reinstalling that battery.
If that doesn't work, you will have to send it in for them to rest the scooba.
  • sleepy_user
    sleepy_user Jan 23, 2009
    I would try calling tech support again. Is it possible that you got an idiot on the phone the first time that didn't know what s/he was talking about.
    I know that has happened to me before.
    Genius:
  • 1,239 Answers
Hi
is all the lights flash in sequence or any beep..
Use the "Clean" button to move forward in the diagnostic series.
Use the "Power" button to move back in the diagnostic series.
  • ABHISHEK.C
    ABHISHEK.C Jan 24, 2009
    as all the lights flash in sequence or any beep..it is
    Error-Code "1":
    OM Says It Means: Vacuum Malfunction
    OM Says Do This: Remove and rinse Scooba's filter and vacuum port.
    Elaboration: It is implied that something is blocking air flowing through the ducts. No velocimeter-type sensor has been located, therefore the sensing tactic is most likely one that looks for a reduction of 'fan-motor current'. When air-flow through the blower is blocked, motor-current will decrease slightly. It must be assumed that Scooba detects that difference in fan-motor current and issues error-code "1".
  • ABHISHEK.C
  • 124 Answers
Try to remove remove the battery pack and hit the two buttons again then put the battery back in and hit the buttons hold for 20sec i hope this helps
Hello. My scooba 5800 had a check tank light on. I used a straw on the valve and that fixed the problem. Now the scooba runs like nothing is wrong, but there is no actual cleaning going on! It goes the...
Hello, Take the battery out and hold the switch down for 30 seconds, to reset the curcuit board, then charge back up for 12 hours. this should take care of it. If I can help future please call @ 1561-848-3387 Thank you, Teresa. Clean Sweep Vacuums
Aug 10, 2010 | iRobot 5800 Scooba Vacuum
Tip
IRobot Scooba Guides Tutorials how to total maintenance
IRobot Scooba Guides Tutorials to all you ever need to Fix and Maintain
on Apr 26, 2014 | iRobot Scooba 380 Robotic Vacuum
It leaves water after finished. That's the first time I use it but it leave water on the floor and it stops.
According to iRobot make sure that the Scooba is clean, including the parts (vacuum hose & filter, bottom roller)
Make sure the battery if fully charged, and that you let it complete the cycles!
May 15, 2010 | iRobot 5800 Scooba Vacuum
Cant remove top to get to the tanks
I had this problem and got the solution form i Robot customer service:
1. Put the Scooba on a solid surface
2. Press on the back of the tank on the IRobot logo
3. At the same time push down on the front switch
Good luck, it works for me.
Sep 14, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Have Scooba 340 that won't power on after battery fully charged!
No repair services anywhere, unfortunately. It does sound like you might need a new battery, but the issue could also be the power button. I suggest giving us a call at 1-877-855-8593 so that we can more accurately determine what the problem might be and how we can most efficiently help you to solve it.
Fembot
iRobot Tech Support
Aug 15, 2009 | iRobot 5800 Scooba Vacuum
Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
May 10, 2009 | iRobot 5800 Scooba Vacuum
When i charge,the service light is on and beeping
get back to the person that you bought it from i would think they would give you some kind of waranty.i don't trust buying from ebay .i hope you didn't pay a whole lot for it.send an email to ebay themselves.please leave feedback
May 04, 2009 | iRobot 5800 Scooba Vacuum
I cant open my scooba
If you haven't used the scooba before or if it has been a long time, the pump may need to be primed.  Go to irobot and do a search for how to do this.  I also had difficulty opening my scooba.  Press down with the palm of your hand on the back silver plate as you push down on the silver release handle.  This worked for me.
Apr 28, 2009 | iRobot 5800 Scooba Vacuum
Battery door will not open
You have to push down on the plate to open the door. Make sure Scooba is on a flat surface, then push down. If the door doesn't release, try again. It sometimes takes a few tries, but that should work. If not, call iRobot Support. They are great and have helped with everything. I love my Roombas and my Scooba!
Jan 05, 2009 | iRobot 5800 Scooba Vacuum
iRobot 5800 Scooba Vacuum Logo
7,513 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
