Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Reverse issues On my 98 XC 600 when i put it in reverse it grinds and will not engage or move... It drives fine in forward.
  • 4 Answers
I believe that your reverse gear is a kit. Now they are not gear driven, they actually run the motor in reverse to back you up, anyways, if you look down from your reverse lever, you will see a adjuster nut or guide bolt. try adjusting that some. you definitely don't want to keep grinding those gears!! reverse kits are around 500 bucks. Good luck
Posted on Jun 20, 2009
Why would a vehicle in reverse move forward
The question is a little vague but I think I know what your referring to. All modern automatic transmissions have torque converters. This is the device that connects the engine to the transmission. All vehicle manufacturers like the trans to be nice and smooth shifting. That's great but it does come with some minor drawbacks. If you are facing slightly down hill and you put your car in reverse but do not step on the gas slightly I can guarantee that you will indeed roll forward. You can eliminate that issue by holding your left foot on the brake while you shift into reverse. Then, as soon as you feel the trans engage, gently depress the gas pedal with your right foot and it will eliminate that forward roll problem.
Sep 25, 2014 | Cars & Trucks
No forward engagement in drive position
If engine revs go high and no forward movement you most likely need a new transmission
Jul 11, 2017 | 1999 Ford Contour
Audi a3 auto reverse gear doesn't move
run fault codes and look for faulty TCM and reverse servo .
Nov 29, 2013 | Audi Cars & Trucks
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
97 wrangler wont drive forward in 2wd. just makes a loud grinding noise but will drive in reverse
sounds like rear end is coming apart
google wrangler forums and post there
Feb 03, 2013 | 1997 Jeep Wrangler
Won't drive in reverse
Failed Transmission Again
Part with it
Get something else
Maybe American (Rear Wheel Drive Only)
Dec 12, 2012 | 2001 Mazda Tribute
What is it when in reverse the automatic transmission on a 1999 Camaro grinds?
Reverse is not "synchronized" forward gears are, so it does make some noise, try shifting to 2nd before engaging reverse to slow gear rotation and limit gear clash or grind.
Oct 08, 2012 | 1999 Chevrolet Camaro
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
Mercury 115 problems
This could me that reverse gear is not fully engaged.Adjustment on the cables is needed.Take the cowlings off.With the motor not running,move the throttle/gear selector into forward and reverse.You will see where the cables move in the engine area.Note which way the cable moves the selector when reverse is selected.Do this next bit from inside the boat.Hook up the flusher to the motor and start it.Select reverse.When you hear the grinding,push the selector by hand in the direction of travel.It should engage the gear fully.You will see the adjustment threads on the control cables.Move to suit.Hope this helps
Jul 28, 2009 | Boating
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
590 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
