Code to program audio engine A5+ speakers with time Warner cable tv remote
cezirkle
  • 27 Answers
SOURCE: sony tv codes
Greetings...
What is the number for the TW remote you are using? 8400, U62R, 2000? Which TW cable service in NY... NYC, NY & NJ, Albany, etc...?
Ed
Posted on Apr 03, 2008
SOURCE: Programming Scientific Atlantic remote to work with New Dynex TV
dynex is bestbuy's product try emerson, mine is working with emerson codes
Posted on May 23, 2008
SOURCE: Code for cable TV remote - 26" Insignia 720p HDTV
I just bought a 32" Insignia NS-LCD32-09 using the Cox (suddenlink) remote and the code 0463 worked fantastically for me, Thanks!
Posted on Dec 12, 2008
  • 267 Answers
SOURCE: Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
Posted on Mar 06, 2009
SOURCE: My Time Warner cable Remote will not program to my TV.
I had the same problem, so I followed these steps and it worked!
1) Turn on TV.
2) On the remote control, press TV once (it will blink once). Then press and hold SETUP until the TV key blinks twice.
3) Enter 9 9 1, (the TV key will blink twice).
4) Aim the remote control at the TV & press POWER once.
5) Press & release the CH+ key continously (you may need to press it more than 50 times!), then stop when the TV turns off.
6) Press POWER. The TV should turn on, then immediately, press SETUP to lock in the code.
Posted on Aug 22, 2009
Time Warner codes for Mitsubishi tv
If Time Warner remote is universal, you probably can use its code search feature to find something that will control your Mitsubishi TV. Also, Time Warner might be able to tell you what code to use.
Jan 14, 2015 | TimeWarner Cable Time-warner cable...
Universal remote control programming
If you wish to get more details about how to program a remote control, check this link. http://electrohelponline.blogspot.com/ Set-up code list and set-up procedure to many popular brand remote controls are given in detail. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 25, 2013 | TimeWarner Cable Time-warner cable...
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
How do i program this remote to my time warner cable box
Time Warner is most likely made by another company and they are not listed on the programming documentation. You can try looking online to see who makes your Time Warner box. You should be able to program the manufacture off of the program list. The universal code for this remote is 8107 and 8108 which may work as well. To program the remote press set and the light next to set will start flashing. Press the desired component button ex(TV , VCR, CBL, DVD). Next enter the code 8107 and press ENTER. The set light should no longer be flashing. If 8107 does not work try 8108 using the above info.
Feb 06, 2010 | Sony RMV210 Remote Control
Feb 27, 2009 | Panasonic Televison & Video
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Time warner code for Fujitsu 42" tv
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066
let me know if that works for ya
ric
another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
Nov 10, 2008 | Toshiba 36A50 36" TV
Volume control
We forgot the very last step in programming. I tried programming one more time today and it worked so now everything is working correctly!!
Nov 05, 2008 | Audio Players & Recorders
Programming remote control to Cable TV Box
What you need to do is contact the manufacturer of either your remote control otherwise the manufacturer of the Time Warner [aka: cable providers some times also have the info on file for their customers] they store the code information within their internal systems for their customers such as yourself. Otherwise there is normally a paper insert with the remote control or the Time Warner that would list the info for select manufacturers on there. Toshiba has pretty universal IR signals/codes so you should be okay when trying to program in the codes. The manufacturers can also assist you through the steps--believe me it can get frustrating some times!
Jun 02, 2008 | Televison & Video
Televison & Video Logo
294 people viewed this question
Top Televison & Video Experts
