Question about Bassett Cottage 3-in-1 Crib
How do I change a Sleigh Crib into a double bed?
I have gone out and bought rails and mattresses but now I am not clear on how to change this crib into a bed. I dont see where the rails attach to the head board and foot board without drilling holes into the boards? I also want to know was i supposed to buy a certain type of rails? Reason I ask is that I don't see any feet for the bed , seems strange for the rails to lay on the floor? Please help.
    Genius:
  • 1,239 Answers
Hi
any conversion kit came with it..
usualy sleigh crib converted into a double bed by adding the conversion kit
Posted on Jan 23, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 23, 2009
    To convert each to the twin bed configuration, the outer vertical rail
    members are removed and the central member is rotated ninety degrees.
    The rotated members form the twin headboard and footboard. The rotated
    members may be re-configured to provide a higher headboard than
    footboard in the twin configuration. The mattress frame assembly is
    also re-configurable between the crib bed configuration and the twin
    bed configuration, by pivoting extension frame members between
    perpendicular and parallel positions relative to a central frame
    member.
  • ABHISHEK.C
    ABHISHEK.C Jan 24, 2009
    any clarificationsZ?
    Brigadier General:
  • 3,614 Answers
Here's HOW..
STEP 1: Mount one Side to the rear posts of the Headboards. Use four Decorative Bolts to fasten the side to the posts. DO NOT tighten the bolts yet.
STEP 2: Install the Mattress Support Spring in the crib with the flat side up. Extend the mounting flange on each corner and attach the spring to headboard and footboard at the desired level using four Hex Bolts and Hex Wrench provided. The top position is recommended for newborns. The bottom position must be used when the baby is able to kneel or stand in the crib.
STEP 3: Mount the other Side to the posts of the Headboards. Use four Decorative Bolts to fasten the side to the posts. Tighten all bolts, including the ones from the first side, with the Allen wrench provided.
STEP 4: Once the crib is in use, periodically check to make sure all bolts are tight, and tighten as necessary. For future use, keep these instructions in the plastic bag attached to the mattress support spring.
  • 1 more comment
  • micromaster
    micromaster Jan 23, 2009
    Conversion to Toddler Bed:
    • Mattress should be in lowest position.
    • Remove one Side by unscrewing the 4 Decorative Bolts holding it in place.
    • Be sure to loosen all the other Decorative Bolts before attempting to remove the Side.
    • Once removed, attach Toddler Rail (sold separately) using two of the Decorative Bolts you just removed and the Shorter Bolt packaged with the Toddler Rail, and retighten all remaining Decorative Bolts.
  • micromaster
  • micromaster
    micromaster Jan 24, 2009
    tretam,
    any update to your post problem..?
    tnx
    Brigadier General:
  • 5,158 Answers
If the railing are not made for that crib DO NOT use them as your child can be severely injured if they are not installed properly which is likely to only happen if the rails are made for the crib.
Robert
    Genius:
  • 1,550 Answers
You can get instruction from manual
Here is link for manual
The instruction to convert into bed present in it .
I need the instructions for the cosco heritage collection crib model number da0504kmc1w
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
May 17, 2009 | Baby Gear
Need instructions ofr converting crib to a toddler bed.
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
May 16, 2009 | Bassett New Haven 3 N 1 Crib
Assembling Instructions model 01720-1
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
Dec 13, 2008 | Simmons Mattress Matino - Natural Maple...
Transfer
All you have to do is remove the plastic slider rails on the top and bottom of the front rail and take off the rail. This bed still has 3 rails like a daybed when it is changed into a toddler bed.
Jun 04, 2008 | Cosco 2-in-1 Sleigh 10121 Crib
Model 4624-1 Delta Luv Crib
If its like mine, you just remove the front panel that went up and down. Then lower the wood mattress support to the lowest level. You are now ready for the toddler bed. Once you want to convert to a double bed frame. You have to purchase a metal frame that holds the bed. Then attach the back and the front to the metal frame. This should like a sleigh bed. Good Luck, Nicol
Mar 01, 2008 | Delta Luv Delta - Baby Products 5-in-1...
HOW DO I ACTUALLY CONVERT A 3 in 1 CRIB TO A BED?
I have two children and I changed their beds from the cribs to the day beds by taking the front or footboard part off.  You have to save this part because in order to change it from the day bed to a full bed, you have to buy a siderail kit, take the sides off, and attach the siderails to the headboard and footboard.  Hope this helps!
Oct 11, 2007 | Bassett Cottage 3-in-1 Crib
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Bassett Cottage 3-in-1 Crib Logo
254 people viewed this question
Top Bassett Baby Gear Experts
Jennifer Rock
Jennifer Rock
Greg Cann
Greg Cann
ray gallant
Are you a Bassett Baby Gear Expert? Answer questions, earn points and help others
