Question about Refrigerators
Frigidaire refrigerator model# lghn2844mf the door open alarm keeps going off and all the doors are completely closed
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
ghappliances
  • 126 Answers
SOURCE: Door Alarm
SOMETIMES THE DOOR MIGHT SEEM PROPERLY CLOSED BUT ITS NOT TRY RE ADJUSTING THEM AND SEE IF THAT WORKS ALSO THE DOOR CLOSED CONTACT CAN CAUSE THE BUZZER TO GO OFF FOR NO REASON.
GOOD LUCK.
MOHAMED
Posted on Sep 20, 2008
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Posted on Aug 08, 2009
  • 93 Answers
SOURCE: Refrigerator gurling noise when door closes
There is a water evaporation tray in the back of the frig. Air pressure fron closing door makes air bubble thru tray. Its not a problem.
Posted on Aug 29, 2009
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 03, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
Door ajar signal keeps beeping on refrigerator
Locate the door switch if possible and operate by hand to see if pushing the switch in will turn off the light. If the light goes off, the door may not be turning it off when closed. Could also be a faulty switch.
Mar 07, 2015 | Frigidaire Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Frigidaire FFHS2612LS4 wont stop beeping
Hey Brandon, this is JK. Thank you for your post. I understand that your refrigerator is beeping none stop. When the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut off. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm will reset. The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping. Check to make certain that the gaskets on both doors have no gaps and that the appliance is maintaining the desired temperature. If all of these suggestions pan out and the problem still persist, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Hope this helps!
Mar 10, 2014 | Frigidaire FRS3R5EMB Side by Side...
Beeping & not cooling
Hi Hope, usually when the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut OFF. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm is reset.
If the alarm keeps on going off after the doors have been closed and unit has been reset, I recommend contacting a professional technician so they can diagnose and repair your refrigerator.
Sep 10, 2012 | Frigidaire FRS3R5EMB Side by Side...
Kitchen aid open door sensor alarm keeps going off door is closed
Dec 21, 2008 | KitchenAid Architect KBFA20ERSS Stainless...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
