Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Samsung LE40R74BDX TV starts up with chime, switches it's self off again with chime then cycles on/off until mains removed from back. Have read that cleaning fans can repair or that there could be a problem with the light box?? Taken back off bi=ut no fans obvious. Any ideas?
The fault lies with faulty capacitors on the power board,just had mine repaired.
the power board is easy to get to,just remove the back panel and its directly in
the middle.
The faulty capacitors are quite obvious as they start to bulge at the top
I sent mine to a company in Watford called gtvwatford 55 pounds for
the repair and now as good as new. pretty common with this lcd panel
im afraid makes you wonder on the quality of components used as
my hdmi input stopped working a while ago as well, so if anybody knows
how to repair that i would be interested,my panel is just 28 months old
hope this helps
Tony
Posted on Mar 04, 2009
Ln52a550p3fxza wont start cycles on and off
The problem could be temperature related. I replaced both my processor board as well as the power supply board and the problem is still there BUT I found a VERY simple solution that just requires me to keep the TV on all the time. When the TV is at room temperature, it literally takes 10-15 minutes for the system to stabilize and provide a good picture and audio. When my basement was at 55° for a few days, it took over 1 hr for the TV to stabilize. I now switch the input to my Roku player input and leave the TV on all the time. The Roku screensaver kicks in and all is fine with the world. No more issues with the TV not working. It adds to my electric bill but it is cheaper than replacing another board. When the TV dies, I'll get a replacement TV.
Dec 08, 2015 | Samsung LN52A550 LCD TV
Tv picture goes off but soud remains
screen driver is failing. it will need to be replace these parts cannot be fixed by none expert part that goes is the main chip and they don't sell them on the open market. and if you do find one then it will cost more than the board its self. replace the board and put some heat sink on the back of the chips 2 big black ones and it should last longer.
Sep 20, 2013 | Samsung LE40R74BDX 40 in. LCD Television
I hit the remote on button the 52"samsung tv
Tries tv unplug,replug it back like about an hour later.For the tv to resetting itself back to the factory setting,it should be working again.If it is still have the same problems,the causes mostly the power supply board have the problems,that the board where the power a/c cord plug into it.Tries websites like a Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Mar 21, 2011 | Samsung Touch of Color LN52A650 52 in. LCD...
I have recently bought a Samsung SM2033HD TV and want to wall mount it. I can remove the base but how do I remove the collar that joins the base to the TV.
Your tv is not fully VESA compliant. You cannot remove the collar. There are mounts available that grip the screen instead of screwing into the back. This type will look better.
Jan 10, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Samsung 40" tv not coming on
I would check out the power supply module for bad caps with bulging tops. Check DC voltages at the output connectors, you should have 5, 12, 24V.
Jan 08, 2010 | Samsung LE40R74BDX 40 in. LCD Television
After about ten minutes the picture goes blank but
It sounds like the main board may have went on the TV. It should be not that costly to replace
Sep 26, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Samsung 40" LCD LE40R74BDX screen flickering all different colour
You either have bad Main bd and or a bad T-Con bd on the Panel. Have a trained samsung tech troubleshoot the set.
Jun 30, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Samsung HL5067W power cycling
It's simple. Your TV does not like you. Perhaps you need to speak kindly to it before you force it to watch BBC for hours. Buy it a scone.
Sep 29, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
200 people viewed this question
Henry  Thomas
Henry Thomas
