Question about GE Profile PFSS5NJ Bottom Freezer Commercial French Door Refrigerator
Water dispenser paddle doesn't work on GE refridgerator
Press paddle and no water. Water filter is new. Paddle is intact.
2 Suggested Answers
  • 195 Answers
SOURCE: i changed water filter on ge profile refridgerator now water doesn't dispense
HI.HAVE U TURNED WATER ON? :) GOOD LUCK
Posted on Jun 29, 2012
I have a GE refrigerator water comes out but it's not making ice. Bought a new filter.model number GAL25JFXN LB
there are several possible causes for your symptom: failed water valve, failed dispenser microswitch, or the line has frozen solid where it runs close to the freezer interior approximately 4 inches from where it dispenses. push a long plastic zip-tie up the water line above the water dispenser paddle. if it stops against an ice blockage you will need the water line heater kit from GE.part#WR49X10173. If there is no blockage, remove the rear service panel and follow your supply line to the water valve...have a helper push the dispenser paddle while you feel the valve body- if there is no hum or vibration you may need a new valve#WR57X10032. things get more complicated if neither of those tips help, time to call a Tech!
Apr 08, 2016 | GE Refrigerators
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
How to repair refridgerator ice water dispenser paddle
Not a person in this world can help you without a model number? If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 04, 2014 | Whirlpool Refrigerators
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I have a GE Profile refrigerator model PFSS5PJXA SS, French doors with bottom freezer and water dispenser, no ice, on right door. A small rubber disk fell of from behind the paddle that the glass is...
I removed the control panel (2 tabs under the front edge) removed the 4 screws holding on the paddle assembly and removed the assembly. The disk is glued on the back( I used super glue). If it happens in the future I would try to glue it on without removing everything. If you use a mirror you can see the detent where the disk mounts to the paddle and glue it back on. The disks function is to push on the switch that is located behind a gray rubber panel behind the paddle.
Aug 06, 2010 | GE Refrigerators
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
GE Profile PFSS5NJ Bottom Freezer Commercial French Door Refrigerator Logo
18 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
