Question about IBM NetVista M42 6290-xxx 512MB DDR PC-2100 Desktop Memory
How to open the case (IBM NetVista 6290 31J)
bunnydawg
  • 5158 Answers
SOURCE: Model # IBM NetVista PC Desktop
when you boot hit pause when it gets to the screen just after the memory screen is finished. hit the pause button... it should say which key(s) to hit to enter setup.
Is there a bios password and you can't get past that ?
Robert
Posted on Sep 01, 2008
leethedeuce
  • 4472 Answers
SOURCE: ibm netvista 6792-11u cannot display
Have you tried installing a different video card?
Thanks,
Lee
Posted on Jan 21, 2009
  • 243 Answers
http://ati.amd.com/support/driver.html
Posted on Aug 16, 2009
  • 1705 Answers
SOURCE: My hard drive is failing on an IBM NetVista 8305
I've had a quick look a a photo of your motherboard and it looks like it supports both SATA and PATA IDE devices.
Have a look inside the tower, if you current HDD is connected via a fairly broad grey ribbon cable, its using a PATA IDE interface - the older fashioned one.
If its connected with a fairly narrow flat red coloured cable, then its a SATA interface.
Remember to set the jumper settings on your new drive to match those on your old one.
Posted on Mar 14, 2010
Joed911
  • 4338 Answers
SOURCE: how to open my ibm
Removing the cover
To remove the cover, do the following:
1. Remove the thumbscrews from the rear of the computer and slide the cover
toward the rear of the computer.
Replacing the cover
To replace the cover, do the following:
1. Ensure that all components have been reassembled correctly and that no tools
or loose screws are left inside your computer.
2. Clear any cables that might impede the replacement of the cover.
3. Position the cover over the chassis so that the front edge is approximately one
inch away from the front bezel.
4. Lower the cover down over the chassis so that the rail guides engage the rails.
5. Slide the cover forward. You might need to lift the front of the cover slightly to
align it properly.
6. Insert the three thumbscrews into the holes in the cover and the chassis and
tighten.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Posted on May 23, 2011
I have no IBM Drivers can please send me
Hi. You may download drivers from Lenovo/IBM website. Here is the driver download page http://www-307.ibm.com/pc/support/site.wss/migr-4mvu6p.html
There are several models of NetVista so make sure that you choose the correct one.
Let me know if you have more questions. Thanks.
Aug 18, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
Netvista 8311 desktop...How do I open the case to get inside of it for memory addition
Click these links for each step please, or copy and paste them into your address bar.
Cover removal:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42851
And
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42924
Front Bezel:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42848
Memory :
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42930
Feb 28, 2010 | Computers & Internet
Video drivers for netvista
Hi friend,
You need to Open www.ibm.com then click on download option after that you need to enter your moder no in search box...then you will find out link for download...
Dec 22, 2009 | IBM NetVista 2.4GHz Pentium 4 Desktop...
My IBM NetVista is not coming up...power does not come up..dead
take the cover off the Pc and disconnect the pwr supply
Aug 15, 2009 | IBM NetVista X40 PC Desktop
Unable to boot
hello there!
Depending on what system is, you (BIOS) usually you press a sequence keys, like DEL, PF10 or PF11 when system start, usually IBM models is ESC key to go on BIOS.
Open Sky
Jul 24, 2009 | IBM NetVista PC Desktop
I need install the my lan driver
Hi
Open following link and select your system model from Netvista A30p section.
IBM
Thanks
Mar 19, 2009 | IBM NetVista A30p PC Desktop
Monitor screen shows all sorts of colors in line patterns.
with the information I gathered IBM netvista does not features a video card, it is inbuilt. So it shares your system memory. just open the sysyetm chassis and take out the RAM module and clean the contact edge with a rubber eraser (pencil eraser). Re insert the RAM module and try again.
If the problem persists. try changing your memeory module(s).
Oct 28, 2007 | IBM NetVista PC Desktop
IBM NetVista unable to bootup
This happens when the reset button inside is stuck. If the system is under warranty. Opening the case will void warranty. If it is out of warranty.... Open the cabinet and you can find a chunk of wires crowded in to a point on the motherboard. If you care fully inspect you will find a pair of pin (jumper pin) marked "RESET". If there is some obstacle that is shorting the contact, remove it and offcourse clean the dust particles or other material that could cause trouble. This should solve the problem
Sep 27, 2007 | IBM NetVista PC Desktop
IBM NetVista M42 6290-xxx 512MB DDR PC-2100 Desktop Memory Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
