Question about JVC Car Audio & Video
How many watts is a JVC KS-AX430 amp - JVC Car Audio & Video
5 Suggested Answers
artbesio
  • 55 Answers
SOURCE: hi i wonder if u can help me dont really
You can always put higher than 1000 but it won't make much difference if your amp is only 1000 watts then it will only put out MAX 1000 watts.
Posted on Mar 10, 2009
  • 113 Answers
SOURCE: I have JVC KD-S25 @
check your ground and power
Posted on Sep 04, 2009
SPL Freak
  • 63 Answers
SOURCE: how do i turn my protector light off of my amp?
I'm not really sure how your amp works but i can tell you that if that light is on there is probably something wrong. Check your ground wire. Also it could be your not getting enough power to your amp, or too much
Posted on Mar 06, 2010
  • 4 Answers
SOURCE: Speakers with JVC KS-AX6700 Amp
yeah u want beat or music
Posted on Jul 06, 2010
I just bought a VC KS-AX4302 amplifier. When hooked up to power, the amp immediately turns on and the deck turns on and starts playing music, with no key in the ignition. Both stay on until the power is...
You must have gotten the power lines mixed up. You need to connect the power to the amp and radio the the switched side of the power supply. Or, you connected the amp power and the amp switch wire, usually the blue wire in reverse.
Oct 08, 2010 | JVC Ksax4302 Bridgable 4-Channel Power...
I have a JVC ks-ax302 amplifier and the sound is surging(on/off) the sub still has sound. I noticed when the sound is surging the green light on the amp also surges. I checked the power inputs the both...
Check the RCA cables, this is generally a sign of the RCA cables grounding in the insulation. This would be if you are getting a sound like a heart beat from your subs.
This is a 160 watt amp though.
Could also be a weak ground. Make sure you use a solid ground like the seat belt bolt or brace behind the back seat. A solid ground is best if you remove any paint before bolting the ground down as well.
Also might be the amp is clipping. Try reducing your gains and double check to make sure you are using the proper wiring diagram. This is a 2 ohm stable amp, any lower ohm load will cause problems with the amp.
Jun 24, 2010 | JVC 4-CHANNEL POWER AMPLIFIER Car Audio...
How do i turn my protector light off of my amp?
Mar 06, 2010 | JVC KS-AX7300 Car Audio Amplifier
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
I cannot find the specs or user manual on the JVC archived items list. A few sites want to charge $10.00 for the user guide info, but I think that is too much to charge.
Defiantely not 200 watts
KS-A82
  • 2 Channel Amplifier
  • Bridgeable 2 channel amplifier
  • Output power: 25W x 2, 20 - 40,000 hz at .08 THD
  • 2 ohm stable
  • Adjustable gain (.1 - 2v)
  • MOS-FET DC-DC converter
  • Multi phase connection
  • 1 Pair of line input terminals
  • Remote relay turn on system
  • MSRP: $159.95
http://www.admtechusa.com/JVC.html#KS-A82
May 22, 2009 | Car Audio & Video
Amp makes noise. I am purchaseing a new amp
Hello termite440,
A mono amp will generally provide more power for subs. And for those Audiobahn's, you'll want something that will provide a minimum of 500-600 watts RMS to each, a least a 1000 watt amp. At the low end, something like the Alpine MRP-M1000 or the Orion HCCA-D2400 will provide 1000-1200 watts. I'd recommend the Alpine. For more power, and another $100, look at the Alpine M2000, or for another $250, the Rockford-Fosgate T1500-1bd.
Hope this helps.
Apr 28, 2009 | JVC KS-AX5500 Car Audio Amplifier
Color code for speaker out on a JVC KS R140 car casette player
White - left front
Grey - right front
Green - left rear
Purple - right rear
Yellow - memory power
Blue - remote power (power ant, amp or eq power)
Mar 20, 2009 | JVC KS-F150 Cassette Player
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
