Question about Health & Beauty
What is the best body wash for female athletes
2 Suggested Answers
jp80956
SOURCE: I'm a h*o*r*n*y female 15 year old teenager and I'm looking for guys my age or older, from about 15 - 45, to talk or webcam with. Respond if your interested! Pleeaasse.
jason.hughs7 is my skype. Will enterain you how ever you like
Posted on Oct 23, 2012
How should we take care of polyamide fabric?
Polyamide fabric is a high-performance fabric commonly used to manufacture athletic clothing and moisture-wicking activewear such as socks, pants, shirts, shorts, sweatshirts, sleeves and gloves. It has the feel of soft cotton, yet unlike cotton, it is waterproof and breathable, which helps your body maintain a comfortable temperature and wick away moisture when exercising. Polyamide fabric is washing-machine safe, but should only be washed with cold water. I suggest you look for the Polyamide fabric site. There you will get different varieties, design and best materials also. They provide best services to us. I really like their product. You will also try once.
Jan 06, 2018 | Washing Machines
Plural possessive form of athletics
Athletics' .........for instance "We know that athletics' benefits are good"
It is awkward grammar though, you would say "the benefits of athletics"
Feb 26, 2015 | Computers & Internet
What can I do with my old running shoes?
You can donate them; Nike Reuse-A-Shoe program (www.nikereuseashoe.com) accepts donations of all athletic shoes that don't contain metal. The shoes are converted into athletic surfaces (running tracks, soccer fields, basketball courts) that are sent to underserved communities around the world. And One World Running (oneworld)
running.com; previously Shoes for Africa) will send your new or gently used shoes to athletes and children in Africa, Mexico, and South and Central America.
Jan 14, 2013 | Running
How do I reset
Hi!
Press the Set button to turn on the unit (once programmed, tapping a Personal
Key turns on the unit.) The unit will beep to confirm activation, the Personal Key
numbers (1,2,3,4) will be displayed, and the display will flash.
If you don’t operate the unit for sixty seconds after the unit has been turned on, the unit
will turn off automatically.
If you make a mistake or want to turn the unit off before you have finished
programming it, press the Weight-Only Key to force quit.
Press the Up/Down buttons to select a Personal Key. Once you reach the
Personal Key number you wish to use, press the Set button.
The unit will beep once to confirm.
An arrow icon appears on the left side to indicate age setting.
Use the Up/Down buttons to scroll through numbers.
When you reach your age -press the Set button.
Use the Up/Down buttons to scroll through female or male,
Female/Athlete and Male/Athlete settings, then press the Set button.
Use the Up/Down buttons to specify Height and
The unit will beep twice and the display will flash all data three times to confirm the programming.
The power will shut down automatically.
Good Luck! :)
Cathy
Oct 21, 2009 | Tanita BC 554 Ironman Innerscan Body...
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
When to use Athletice setting?
Hi Susan,
Unfortunately with those body comp scales too many things can affect the reading and are not really reliable. If she drank water or even took a shower/bath before it changes the results. But by chance does she have implants? I have them and read at 26% in either mode but actually with calipers i am 14%. i would use the normal mode majority of the time (athletic is someone who has low body fat or highly active) or just use calipers as it gives a more acurate number :)
Mar 13, 2009 | Tanita 300WA Body Composition Analyzer /...
Fat percentage question
Some body fat percentage levels are more culturally valued than others, and some are related to better health or improved athletic performance. Ideal percentages are also based on age categories as well. The recommended amount for women is 20-25% and for men is 8–14%. You can find a more detailed body fat percentage chart at your local dietitians and nutritionists, and on the internet.
Aug 27, 2008 | Detecto 8450 Low Profile Digital Pediatric...
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
