Question about Pioneer CT-W205R Single Dual Cassette Deck
Faulty Pioneer CT-W450R
I have had this unit in storage for 5 years, it is like new. When I set it up, the motors for the tapes will not turn, although they did briefly when I first activated it.
All the other lights come on, but it just sits there. No movement.
Can you advise on possible troubleshooting?
Thanks
Bill, Vancouver, BC canada
  • Pioneer Master
  • 5,444 Answers
Check to see if their is any voltage going to the motors. If not look at the power supply. Electrolytic Capacitors dry up when not being used and can cause faults like that.
Posted on Jan 25, 2009
2 Suggested Answers
  • 4234 Answers
SOURCE: Faulty CT-W450R
The rubber belts inside the unit have gotten stiff and slippery. All belts should be replaced. That will resolve the problem.
Dan
Posted on Feb 18, 2009
Pioneer ct-wm60r reads err, has new belts,
There are sensors in the unit that are false triggering and some mechanical parts that require alignment. It can take two or three hours to put it back right if you are not familiar with that transport.
This is why I tell people to stay away from changers and auto reverse units as sooner or later they will be a real problem for someone to fix.
Dec 20, 2016 | Pioneer Audio Players & Recorders
I turn the unit on I have power to the unit. I put a tape in to play and the tape does not play. nothing happens. the last time I used it was about one year ago.is there some kind of belt drive motor or...
The belt drive unit is only ran by a SMALL rubber band. It may be that the actual band is broken or the motor itself is shot. Unplug the stereo from the wall and remove the cover CAREFULLY, look in at the tape drive and check the "RUBBER BAND" first.
Mar 16, 2008 | Audio Players & Recorders
Why one tape at deck A won"t come out. it stock inside unit
There are lots of causes to this. For example the mechanism has jammed. The tape has become entangled in the capstan or elsewhere. Plastic damage causing the mechanism to not move back to the eject position. Some decks have a powered eject that is faulty. Broken spring, or one that has fell off.
May 28, 2014 | Pioneer CT-W205R Single Dual Cassette Deck
Pioneer ct 95
Supply reel sensor.
Mar 06, 2014 | Audio Players & Recorders
My pioneer ct-f7171 cassette deck needs a little speed adjustment, where is the pot located?
Usually on the back of the servo motor. You need a speed alignment tape and frequency counter or wow and flutter meter to do this adjustment correctly. Often times the speeds go up as the motor start to fail.
Aug 12, 2011 | Pioneer Audio Players & Recorders
Trying to locate a pioneer cassette player, tape drive belt, for CT 506 model.
I'm not sure what country you're in but below is a link for a complete set of 5 replacement drive belts for your CT-506.
http://www.vintage-electronics.cc/pioneerkits.html
If you need any further assistance then just ask.
Please leave feedback.
Cheers
Andy
May 09, 2011 | Pioneer Audio Players & Recorders
The balance of the rec level is not good how to solve the problem on the ct-w208r cassettedeck player? this unit is brand new out of the box.
Clean the Tape and erase head (these are the small block stainless and white plastic which the tape passes) with cotton ball slighty damped with rubbing alcohol
Jun 04, 2010 | Pioneer CT-W208R Single Cassette Deck
Faulty drive motor
Have you tried contacting Pioneer for a list of their spares agents?
Apr 11, 2009 | Audio Players & Recorders
Faulty CT-W450R
Dan
Jan 23, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
321 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
