Question about Swann Communications DVR4-Pro-Net 4-Channel Security System with 8.4" Monitor
Fixing Camera I have a swann Camera Model sw231-wdc, i mounted it on a 360 degree swivel base,wires were frozen and pulled apart. While putting the wires back together, a blue wire came a loose and i don't know where it goes. If i had the wiring diagram i could fix it. Thanks Ronnell..........
  • Rob
    Rob May 11, 2010
    Call Swann and tell them to send you a wiring schematic. Does it connect to a plastic piece that plugs into a board?
3 Suggested Answers
  • 9 Answers
SOURCE: micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Posted on Jun 05, 2010
chloef
SOURCE: WHAT IS THE WIRERING DIOGRAM FOR A SWANNS S/N 274540212130041 SECURITY CAMERA?
you have the part that broke you need to reattach is and it will work
Posted on Oct 15, 2014
HOW FAR CAN THE PEDESTAL STAND 'SWIVEL'? I CAN GET ABOUT 15 DEGREES EITHER WAY - IS THIS THE LIMIT OR CAN I ADJUST TO INCREASEDEGREE OF 'SWIVEL'?
I believe this is the limit, physically altering the engineered base for this television may put it in danger of falling or breaking. It's a 40 inch LED TV and really not that heavy, perhaps you could look for a lazy Suzann type of base that you could put beneath the TV to give you more extreme swivel capability.
Apr 17, 2015 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Need a wiring diagram for a Swann security camera model 642 3960 it has 9 wires what I cook the wire where the wires go do the wiring diagram
1) Turn the power off.
2) Remove the printer cover.
3) Remove the ink roller by turning it counterclockwise and
pulling it upward.
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place.
5) Put back the printer cover
Mar 06, 2015 | SWANN Home Security
How do i wire my servalance cam swann wierlessY model no. SW231-WCH N3960 to my tv
you have to tune with the dial on the wireless box very slowly.
Dec 10, 2014 | RCA Televison & Video
How do I take a Irwin Record No 23 Vice apart
On this page are several drawings, about these vices.
Look and toy see where the screws are.
after you remove the screws you should be able to pull it apart.
Don't forget the grease when you put it together.
record vice spares record vice spares SWIVEL BASES
Jul 03, 2014 | Irwin Welding Tools
Need a midland model 77-861 antennea
go on ebay or craigs list put your request on there and look it up you may just find one.
Feb 03, 2013 | Midland Radio Communications
Hi, We can not get our TV to swivel. What to we
U have to litterly turn the tv 20 degrees to the left or to the right.If u wanted the tv move to the left or the tv move to the right.The base stand dose not move,it is a solid base stand to hold the tv in with screws.Some tv u can swivels,but only can do it up and down by 20 degrees screen base swivels that it.Take a hold tight of the LCD screen panel and push it up or down 20 degree,that is ur base swivels.
Nov 15, 2010 | LG 37LG30 37 in. LCD HDTV
Swann Communications DVR4-Pro-Net 4-Channel Security System with 8.4" Monitor Logo
190 people viewed this question
Top Swann Communications Home Security Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
 Mikey
Mikey
Are you a Swann Communications Home Security Expert? Answer questions, earn points and help others
