Question about Sony XR-CA330 Cassette Player
Wiring I don't have the owners manual for my sony xrca330 cassette player, so I need to know where the wires go. Thank you
  • 10,594 Answers
Download Owners Manual and Connection Instruction of XR-CA330 from Sony Support. Manuals are free.
Posted on Jan 23, 2009
Does anyone have an install manual or color code chart for a Sony xr-17 am/fm cassette stereo from the 80's?
This is the best I can do for you. I don't see any free manuals on line. In fact, I am hard pressed to find this anywhere else. (Vintage Manuals in Indiana appears closed, although you see web references to it.)
Sony Service Manual for the XR 17 Cassette Player Radio Car Stereo Repair...
Aug 26, 2017 | Sony Car Audio & Video
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
I have a 1995 Pontiac Grand am and it had and old *** cassette player now i"m trying to update it with the sony CDX-GT24W and the wiring colors are totally off. My repair manual tells me what the wires in...
yellow is constant and the red is the acc, black of corse is brown
the matching colored wires grey purple.....
all corraspond to each other
goto sony.com and find the support page find any cd players manual and it should have the exact wiring guide for the sony harness , all of them are the same, they only change with brand i.e pioneer, aiwa, jvc.....
Jul 16, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Luxman Digit synthesized stereo Receiver AM/FM & Phono not work'g
The problem is still there, but I am expecting HELP fir free.
May 11, 2009 | Car Audio & Video
Connection diagram for XR-CA300 SONY car stereo
Hello eliasrvc2,
Sony's support site shows the color codes for wiring both a 9-pin and a 16-pin harness. Click the appropriate harness to bring up the color code table.
Hope this helps.
May 05, 2009 | Sony XR-CA300 Cassette Player
Pre setting the radio station on the keh-p2800 cassette player
HAS TO BE A CONSTANT POWER WIRE THAT CONTROLS CLOCK AND SETTINGS SHOULD BE A 16-14 GUAGE WIRE THE SAY 12+ AND HAS TO BE HOOKED INTO A CURCUIT HAS IS POWERED ALL THE TIME (NOT ONLY WHEN IGNITION IS TURNED ON)
Jul 12, 2008 | Pioneer KEH-P2800 Cassette Player
Sony XR-CA330 Cassette Player Logo
260 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
