Question about Pioneer CT-W205R Single Dual Cassette Deck
Faulty CT-W450R I have had this unit in storage for about 5 years and it is like new. Hooked it all up and although all the lights come on the motors for turning the cassettes don't work. When I first started it, the tapes turned briefly and then stopped. Can you please advise on possible troubleshooting? Thanks ever so much. Bill, Vancouver, BC Canada
  • Scott Mallard May 06, 2009
    I also have a CT-W450R Pioneer casette deck that was in storage. The belts were gummy and of no use. I ordered new belts. Installed them on one side and tried to play it. It will play and go fast forward in one direction, but not the other. I believe that all of the little gears and actuators on it need to be set up but I have no idea how to do this. Any Help?
  • 4,234 Answers
The rubber belts inside the unit have gotten stiff and slippery. All belts should be replaced. That will resolve the problem.
Dan
Posted on Feb 18, 2009
2 Suggested Answers
Grubhead
  • 5309 Answers
SOURCE: Faulty Pioneer CT-W450R
Check to see if their is any voltage going to the motors. If not look at the power supply. Electrolytic Capacitors dry up when not being used and can cause faults like that.
Posted on Jan 25, 2009
Fujitsu Aircon model AST24PBA-W has green Timer light continuously flashing and red Operation light giving 5 flashes. Outside unit fan will not run. What does this code indicate has failed?
Most likely a faulty fan motor. You will need a tech to diagnose correctly as this uses a DC motor which has a circuit board inside so has very specific tests. Other possible faults for this code are compressor rotation error, CT abnormal or current trip all of which will need a tech to diagnose.
Nov 04, 2017 | Fujitsu Heating & Cooling
Stats ignights and goes out
Other similar questions on this site state that this is a problem with the water flow sensor. Although if that is the problem the flame would likely light for only about one second before going out. The water flow sensor fix discussed does not require any new parts. This YouTube video will talk you though it. Good luck.
Apr 02, 2013 | Coleman Hot Water On Demand
Frigidaire lra157mt1
Some of the new style Air conditioners have a auto time delay built into them for power failures. If power fails or you unplug the unit, they will not come back on for about 3 to 5 minutes. This is a safety feature to keep power failures from damaging the compressor. Keep it plugged in for 5 minutes and try again. If still no go then call for service. You should have a 1 year warranty on it.
May 27, 2012 | Frigidaire Heating & Cooling
Head light is not bright enough as compared to other bikes
Hi, Vijendra_443 if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Motorcycle headlight relay mod extra brightness
Tusk Motorcycle Enduro Lighting Kit Dirt Bike Installation
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Sep 09, 2011 | 2005 Bajaj CT 100
Stereo will not power on.
Check to make sure your getting power on the car's harness side, not the radio. Check your 12v constant(battery power), your 12volts switched(ignition) and ground. If they all check out OK then your unit needs to be checked as it may be faulty.
Apr 13, 2010 | Car Audio & Video
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Info 5
Reading online. This error is due to a faulty motor you would need to contact the vendor to see about replacement of motor or defective unit.
http://www.eclipse-web.com/us/contact/index.html
Feb 07, 2009 | Eclipse CD3422 CD Player
Jan 23, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
TV - no audio
TV wirked fine for years, but when we moved it to a new house 100 miles away the sound was gone even the cable supplied picture is great. Cable company couldn't recover the sound either.
Mar 04, 2008 | Zenith B25A24Z 25" TV
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Dec 14, 2007 | iRobot Roomba Red 4100 Bagless Robotic...
428 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
