Question about Asko T701 Electric Dryer
Dryer kenmore model# 11076512695 is not drying all the way it gets warm not hot it all just started about two weeks ago
    President:
  • 1,214 Answers
Check that the vent duct leading to the outside of the house is not partially or fully restricted.
Reply back what you find and I will help you more.
Posted on Jan 23, 2009
We have a Kenmore 400 dryer. It gets warm but will not get hot--it is only one year old --what should we check for?
there are 2 thin coil wires that have current flowing threw it. it gets red hot and provides the heat to dry clothing, if one of these wires brake your dryer wont get so hot. very common its made cheaper all the time so it wont last.
Sep 24, 2010 | Kenmore 62622 Electric Dryer
This is an electric dryer. Over the past week when
one of 3 things could be wrong/1)dry,tight motor bearings/2)drum bearing bad/3) bad motor windings,remove belt off drum and see if anything turns hard i.e. motor,drum each one isolated then run motor w/o drum belt on drum and see if motor gets overly warm or hot especially around the bearing ends
Nov 15, 2009 | Kitchen Ranges
1 week ago the dry was extremely hot and now this week the dryer is cold and the clothes are wet.
Last week your cycling thermostat went bad. This week you thermal fuse went out. This is how it happened.
You dryer cycles on a thermostat. When it goes out the dryer then cycles on the (high limit) thermal fuse. When it goes out. The dryer stops heating. You will find both after you remove the back of the dryer. They are easy to replace. There are two different thermal fuses but if you order the parts using the model number you will have no problem. These two parts are sold in a kit.
Please rate this solution.
Sep 01, 2009 | Kenmore Dryers
I have a kenmore elite dryer model 110 62062100 that has been getting hot (cabinet get very warm on top) and does noy dry all the way. it shuts itself off before its dry. any idea what part is needed?...
most of the time when this happens it is from a clogged wall vent or clogged dryer vent or clogged lint trap,check and clean all 3 and let me know how it does-mike
Apr 22, 2009 | Kenmore Dryers
Dryer not drying correctly
The coils are getting hot and won't open the gas valve. replace them dudes
291385a.jpgMore HERE
Mar 07, 2009 | Kenmore 73952 Gas Dryer
Dryer warm but not hot takes for ever to dry cloths
Bad blower wheel.
Blocked vent.
Lint ball in filter housing.
All of the above.
Dec 17, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
High Heat but does not dry
Check the exhaust tube that goes out the back of the dryer. It may be clogged with lint. Ours did this about a month ago and and a thurough cleaning did wonders. I bought a kit from Lowe's with all kinds of attachments. It was really easy.
May 26, 2008 | Kenmore 62602 Electric Dryer
Asko T701 Electric Dryer Logo
78 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
