Question about Tefal Irons
Schematic diagram of electric flat iron
Simple schematic diagram of falat iron for clothes
2 Suggested Answers
claudeinmo
  • 9098 Answers
SOURCE: Need help with Kenneth Bernard Hair FLAT IRON, not a clothes iron!! Model # is KB2010.
The Kenneth Bernard Vibe Flat Iron - YouTube
? 2:15
www.youtube.com/watch?v=lQklW8kNO90
Apr 7, 2015 - Uploaded by Chatters Salon
The Kenneth Bernard Vibe Flat Iron ... How I curl my hair using aflat iron, extensions and bump its ...
Posted on Sep 16, 2015
Testimonial: "Hi! The flat iron I have is actually not the Kenneth Bernard VIBE; that one literally vibrates. The one I have is its predecessor maybe? I checked out the video, and while it is a great reference, it doesn't help with my issue. And in fairness, I might not have been specific enough. What I need is a user's manual for Model # KB2010. More specifically, I need to know how t use the power switch/temperature button properly. Thank you for taking the time to answer!"
I need a schematic for a Rowenta DW-8080 steam iron
They do not publish such diagrams for this type of product.
Oct 03, 2016 | Rowenta DW8080 Pro Master 1700W Steam Iron...
Tip
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
? 2:15
Sep 15, 2015 | Irons
How do i increase the iron heating temperature (thermostat) in Panasonic Electric Iron NI-22AWJ
Check the voltage at your power point, irons draw a lot of power. most irons have a temp setting switch cool med hot . If this a new iron return for service.
Feb 18, 2015 | Panasonic Irons
Troubleshooting of flat iron for clothes
follow the steps and use the common sense. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Sep 20, 2012 | Irons
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
Does not heat up
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Dec 06, 2009 | Panasonic NIR71NR Iron
Tefal pro express turbo water flowing out of iron and soaking the clothes
i have a tefal pro express gv8110 iron and it keeps leaking out water onto the clothes and doesnt seem to heat up. i have only had it for 22 months so im not sure why it has been doing this. it also doesnt seem to let the steam out like it used too. please could u help me
Sep 08, 2009 | Tefal Irons
Spray broken, can't figure how to take apart to check
You've to open the unscrew the rear screw and take out the rear cover.It's quite hard to fix it if you don't have the schematic diagram. Suggest you odd to have the iron schematic to have step by step as for your easy guide reference.
Rdgs
alan
Nov 07, 2007 | Rowenta Professional DE880 Iron
Irons Logo
450 people viewed this question
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
