Can i buy a lamp only no housing. - Televison & Video
  • 21 Answers
Hello, it depend on the age of your projection set.
Talk with the manufacture's technial support and they should be better able to tell you about buying only the lamp & not the whole housing or all of the lamps.
I hope this helps.
BWLY
Posted on Jan 23, 2009
Philips Mitsubishi WD62525 Lamp with Housing 915P020010 Do I have to buy the housing? Do I need to replace the housoing when I replace the bulb?
The housing is part of the bulb cooling system so it has to be properly mounted to cool
I did a quick look for the bulb and yes you can find bulb only BUT they are $10 to $20 more than the bulb and housing !
So it looks like it is cheaper to replace the bulb and housing. As a guess I would say that these bulbs are what someone has found out to be a replacement but can't purchase then as cheap. So to save yourself some money buy the combo.
Sep 14, 2011 | Philips Mitsubishi WD62525 Lamp with...
Hi, i have a ultravision digital hitachi 50v500 , theirs a light bulb in the tv that needs to be replaced. how much would that cost to fix it?
Replacement lamps with housing will cost between $175-200 at a retail store, this does not include installation. You can buy a lamp without the housing for near $75-100 but this requires you to remove the old lamp from the housing and installing the new lamp into the old housing, which can be tedious and potentially damaging if you do it incorrectly. BUY THE LAMP WITH THE HOUSING it will save you time and frustration.
Mar 03, 2011 | Televison & Video
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
How do you replace the lcd bulb on 55 sony
Here's how to replace a bare lamp w/ out buying the housing(it's a little bit cheaper that way)
http://www.youtube.com/watch?v=xFUVTwPD1HM
Here is how you get the lamp out of the tv...
http://www.youtube.com/watch?v=Eqm59DTodp4
it's much easier to buy the lamp already in the housing and change it that way.
Sep 02, 2010 | Sony KDF-E55A20 55 in. LCD Television
Lamp needs to bereplaced,,,,, tv jvc model 61z886, need to know model of lamp i need and where to buy it
Google "DLP lamp" and you'll get many places from which to order lamps. Go to one of these sites and they should have a search box. Enter your model number and it should give you the part number of your lamp. Try several sites if the first one doesn't give you what you need to know. Once you have your lamp number you can shop the various sites for the best price. Note: You can buy your lamp complete (with the housing it comes in),..... or just the bulb and replace the bad one in the housing (cheaper)..... if you have the skills needed. If not buy it complete with housing. If you change the bulb only,.. don't touch it with your bare hands. Most bulb only packages come with rubber gloves.
Aug 24, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
How do I change the lamp in this tv? Do I need to buy just the lamp or lamp with housing?
If you have not changed a lamp before at all, I would suggest that you purchase the lamp plus housing. This will contain complete instructions on how to change the lamp and reset the counter. Keep the instruction sheet and the old housing and you should be able to replace just the lamp the next time.
Dan
Apr 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
What aftermarket lamps work and what ones don't
I just bought the bulb and housing from a seller on ebay. Its an OEM part that comes with a one year warranty. That is why I made the desicion to buy it for $118. You can buy remanufactured parts for a few dollars less, but if you can get an original part why buy a recyled part.
I read on a different problem how the philips bulbs are better bulbs than the original bulbs. If you go that rought it will cost you about $149, just for the bulb and you will have to remove it from the housing. There are instructions on utube on how to do this. I went with the OEM part because of the price.
http://cgi.ebay.com/PANASONIC-TYLA1000-TY-LA1000-LAMP-BULB-W-HOUSING_W0QQitemZ260367917362QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item260367917362&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1308%7C301%3A1%7C293%3A1%7C294%3A50
Mar 14, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a KDF-60WF655 and the lamp light turns on
Joann,
If you buy an original Sony lamp (and I would recommend you do) you will get the lamp with the housing and the allen wrench you need to change the bulb. You shouldn't need a ballast.The reasons to stick with an orginal Sony lamp:
1)You get the lamp with the housing. Some of the aftermarkets just send the lamp and reflector
2) the originals have far less problems than the aftermarkets. I have seen replacements fail early and not be bright enough.
If you have any further questions, feel free to ask. If you are happy with this solution, please rate it. Thanks!
Nov 18, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Replacement lamp
The lamp you received is correct. I own a lamp replacement company. It may of been pakaged incorrectly or maybe you received just the bulb and not the housing or vice versa (housing included). First, unless housing is damaged NEVER buy a new one...just the bulb will do. Housings are the biggest markup on replacement lamps. They are manufactired at a low cost and usually retailers drive up the lamp price because they include an uneeded housing. The bulb itself (XL-2100U) should be a round bulb. Check out my listing and compare this to what you received:
http://rearprojectionlamps.com/2000u-lamp-p-2277.html
Dec 12, 2007 | Sony XL-2000U Projector Lamp for XBR800...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
