Question about Kenmore Elite 45986 Front Load Washer
Washer shakes real bad in spin cycle
When the washer goes into spin cycle it seems like it is out of balance
  • atlantispool Jan 23, 2009
    Mark it does it no matter how large or small the load with every load.
    President:
  • 1,214 Answers
Does it do this when the drum is empty?If not, then you may be overloading the unit with clothes. Or, the clothes may have entangled into a ball. Untangle and spread out.
Posted on Jan 23, 2009
  • Mark Egan Jan 23, 2009
    Does it shake when empty, and you run it through cycle?
How do I stop my washer from shaking real bad during the spin cycle?
its all about the balance of the clothes in there, a heavier thing on one side can throw it off
Mar 10, 2013 | Washing Machines
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
At end of spin cycle,machine seems to be out of balance. Vibration and noise are severe
1=WASHER MUST BE ON SOLID FLOOR,IF YOU CAN FELL IT SHAKING 2FT OR MORE BACK FROM YOU,YOU HAVE A WEAK FLOOR.
2=BALANCING RING BAD,REPLACE ..
3=MAKE SURE THE TUB IS NOT LOOSE
THANKS LACUZ12
Feb 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Kenmore Elite Front Loading Washer is shaking very bad when it's on the spin cycle. When i level it, it's ok for a while but slowly goes back to skaking again. Any Ideas?
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Kenmore Elite 45986 Front Load Washer Logo
204 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
