Question about RCA F36665 36" TV
Possessed remote and tv
At first I thought my remote had gone nuts because the tv kept showing up the menus and volume controls and mute etc. on the screen. After a few days the front panel started working real crazy also. No matter what button I pushed sometime it would show up as the correct menu and sometimes it would not. Then without anyone pushing anything and all the batteries out of all the remotes, the tv would start runnig through its menus. Finally the on/off switch stopped working correctly. I would have to push the volume button to turn the tv on and unplug it to turn it off. After looking at some other suggestions on this site, I took off the back of my tv and looked inside. I then removed the front panel buttons all together and actually unplugged them from the motherboard. Now the tv works without crazy images appearing. (I run the volume and channel changing through other things) I just have to plug and unplug the tv to turn it on and off. This is okay but I would like to know what that part is actually called (and it's part number) and if you think it would be expensive to buy a new one. And if there is a good place to buy it online. I'd appreciate any help.
  • tiffanie pitre Jul 09, 2007
    This tv is from '99. I looked down at the board but I only see one "ribbon" on the whole thing. All the rest are the wire type of connections. Pulling out the piece that all of the buttons connect to is about the most I can do with my expertise since this is the first tv I ever tried to take apart. :) I am including a picture of the part that I took off. Are you talking about cleaning the actual parts the buttons push? Is this what you call the "switch"? I'd take this to a shop but it was a freebie and is just about impossible to move.
I have the same TV but the picture keeps jumping every few seconds. Antone have any ideas about this?
Posted on Apr 23, 2008
    Scholar:
  • 150 Answers
How old is this set? some of the late 90's early 2ks had issues with the Gemstar module, then you also said that you unplugged the buttons, if unplugging the buttons fixed your problem, you probably have contamination in the buttons and they are $2 switches, I would replace all 8 (if you have 8) as I do in some of the CTC169 Chassis televisions, depends upon your level of expertise and such. This set has the Guide+ system and I think that you might have a Gemstar issue still, it is a little 2" square box that has 2 ribbon cables that plug into it, and is fairly easily replaceable.
Posted on Jul 08, 2007
Need codes to program tv it is a sylvanna tv
U get those codes, if available, from the manufacturer of your universal remote. And remember that a universal remote only offers limited functions such as volume, change channels, mute, power on/off. Video input changes, menus and other items are not included.
Mar 21, 2016 | RCA Universal Remote Control
I need a remote for a Yamaha DSP A3090, Yamaha part VT974300. I'm OK with a universal remote as long as it can access and navigate the on-TV menu.
Be careful - most universal remotes only control the most basic of functions, volume change, channel change, mute, on/off. They rarely include operation of sources, menus, etc.
U are , no doubt, going to need an original unit for the menu access.
Check for remote on ebay or google.
Aug 20, 2015 | Yamaha DSP-A3090
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
May 05, 2012 | Philips SRP5107WM - Universal remote...
Code to programme Sky Remote to operate new TV?
i have the same problem with the codes 0035 0125 0049 everything works except turning the volume up. have you found a solution yet???
Dec 31, 2008 | Televison & Video
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Blinking light on volume control
i have a same problem, but on a rx-v1070, worked fine for a long time and one day i just turned it on and boom light blinking and no sound, if i crank the volume to about 80-90% i get distorted sound, i think our amps are gone, checked the fuses and they seem ok. Most likely its the amp. This unit was around $1200 back in a day. And it still produces sounds better then many recievers in stores today, too bad it has no 5.1ch surround.anybody have a solution pls let me know, for now i have a weak pioneer with 5.1 but no power.
Dec 11, 2007 | Yamaha RX-V870 Receiver
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
RCA F36665 36" TV Logo
64 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
