Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Looking for a ignition coil for Mcculloch MAC3214 chain saw Part # 302138
revskank
  • 203 Answers
SOURCE: McCulloch chain saw pro Mac 10-10
if you are using McCulloch oil 40:1
Posted on Mar 02, 2009
dontbother10
  • 2220 Answers
SOURCE: what is distance from coil to stator 14 in. poulan chain saw
I think you are asking for gap between the fly wheel and the ignition module. A business or index card works great. 0.1 - 0.3 mm. GL
Lou
Posted on Oct 09, 2009
#1 Taper
  • 1040 Answers
SOURCE: how to know were the fuel line runs on a mcculloch
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Nov 30, 2009
dontbother10
  • 2220 Answers
SOURCE: HOW TO TEST IGNITION COIL ON A POULAN CHAIN SAW
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 12, 2010
puertobori
  • 7733 Answers
SOURCE: I need a part cd143f-100a for a chain saw, looks
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 08, 2010
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
Jul 28, 2015 | McCulloch 14" Electric Chain Saw Mcc1514
Hooking up wires on ignition coil on a mac-10-10-chainsaw
There are 2 items that you need to pay close attention to is the air gaps;
1. Air gap of the points, and
2. Air gap between the permanent magnet and the pick up coil.
Use the manual to determine the proper gap size.
Good Luck,
Rich Lilja
Jul 22, 2014 | McCulloch 1975 Pro 10-10 Automatic Chain...
Is a capacitor on a 3200 mcculloch chainsaw also called the coil
starting capacitors on electric chain saws just provide a short burst of stored up energy to get saw moving , coils on gas powered chain saws provide all the electric energy to "fire" the spark plug
the two are totally different and one does not work for the other , but both are an electric device
Jun 05, 2014 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Need a ignition coil for a promac 1000
get make & model number of saw and google.com or yahoo.com or ask.com and type in: want to buy ignition coil for mcculloch promac 1000
or type in mcculloch chain saw parts sales
Oct 04, 2013 | McCulloch Garden
Need replacement coil for my mcculloch chainsaw part mc-302138
Mcculloch whent out of business so the best place to look for a coil would be like on Ebay or Amazon as the parts are getting very hard to find.
Jan 09, 2013 | McCulloch Garden
I have a 14" Mcculloch
All modern chainsaws have electronic ignition, you should first try diss connecting the wire to the ignition switch, to rule out a fault with the switch, if still no spark check the gap between the the unit and the flywheel, this shouls be 0.3mm, if still no spark it will be a replacment ignition unit.
Jul 30, 2011 | McCulloch MCC1514 14Inch 15 HP Electric...
Chain saw starts up runs for a while till it gets hot .then it quits and wont start again till it cools off.
hi
could be breather playing up , but most likley ignition coil breaking down / going open circuit when hot
try another ignition coil , reset air gap to 0.010 "
fit new plug , and make sure to apply loctite to coil mounting bolts/ screws
cheers
Aug 24, 2010 | McCulloch Garden
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
96 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
