Question about i-mate PDAL Pocket PC
Screen Error I have a large blank screen in my screen and the following error appears periodictly: skin name "dellprodreg-skin" file "shell.css" is required in your "sscommon/skin/delprodreg-skin/css/" directory. To fix problem please check skin name in your configuration file or reinstall the application. CAN SOMEONE TELL ME HOW TO FIX THIS?
  • mcastana_99 Jan 23, 2009
    I was unable to access the website.
    Thank you
  • Denverbear49 Feb 17, 2009
    I have the exact same error message. Any solution to this please ?
Kill the Process "bcont.exe" from Task Manager.
Uninstall the program Dell Communication(Support Center) from the add/remove programs..
Posted on May 06, 2010
    Scholar:
  • 76 Answers
  • mj554 Jun 06, 2011
    hi plz help me for align screen problem imate pdal thanks
How to Make a Popup (for Windows)?
Open Notepad (Start>Programs>Accessories>Notepad).
Copy and paste the following text into the program: lol=msgbox("",16,"Error")
26319026-bxzhjmonsmllydp0qa2riq2g-2-2.jpg In between the two adjacent quotation marks, type the error message you wish to appear in the popup (eg. lol=msgbox("Example",16,"Error")).
Click File>Save As. 26319026-bxzhjmonsmllydp0qa2riq2g-2-9.jpg In the 'Save type as' dropdown, change the setting from 'Text Documents' to 'All files'. Then, as your file name, type your file name (when you open the file, it will trigger the popup), followed by '.vbs' (eg. Example.vbs). Then, in the 'save in' dropdown, select a place where you can access your file. When you have selected your desired place to save the file, click 'save' to save your file.
Open 'My Computer' (Start>My Computer) and find your newly-created file.
Open the file, and your error message should pop up on the screen!
Oct 20, 2016 | Microsoft Computers & Internet
Black screen with white arrow
Step 1: Opening a command promptThis error prevents Windows XP from opening. This problem has to be addressed from a command prompt environment. Use the following steps to open a command prompt environment:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears.The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
    NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CD's, press the R key to open the Recovery Console.
    NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
    1. Turn on the PC, and press the F10 key repeatedly at the first screen.
    2. At the Recovery screen, click Advanced Options .
    3. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
  4. When the log in prompt appears, press the number next to the windows version (min int or Windows) and type the log on password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: disk part
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
    • If a disk part prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
    NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered. For more information, refer to Performing a Full System Recovery in XP .
Step 2: Replacing the file from a backup folderUse the following steps to find and replace the L sass file from the command prompt environment:
  1. Type the following at the command prompt: CD X:\i386 (where X is the main drive letter)
  2. Press the Enter key. If the error The system cannot find the path specified appears, enter the following paths, in order, until the error does not occur:
    • cd X:\Windows\i386 (where X is the main drive letter)
    • cd c:\i386
    • cd c:\Windows\i386
  3. Press the Enter key, and type the following at the command prompt: expand lsass.ex_ X:\windows\system32 (where X is the drive letter)
  4. Press the Enter key, and type the following at the command prompt: cd X:\windows\system32 (where X is the drive letter)
  5. Press the Enter key, and type the following at the command prompt: attrib lsass.exe -r
  6. Press the Enter key, and type the following at the command prompt: rename lsass.exe lsass.bak
  7. Press the Enter key, and type the following at the command prompt: rename lsass.ex_ lsass.exe
  8. Press the Enter key, and type the following at the command prompt: exit
  9. Press Enter and the PC restarts without the error. If the error persists, go to the next step.
Step 3: Recovering the PC If the error still continues, recover the PC .
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 11, 2010 | Dell Inspiron 530s Desktop Computer
Online light flashing at times, no internet. Occasional message: failed on loadingskin name comcast; the file shell.css is required in your sscommon/skin/comcast/css directory.
failed on loading skin name "comcast". the file "shell.css is required in your "sscommon/skins/comcast/css/" directory" this is what i am getting from my acer desk top.... comcast is my internet service provider and say "everything is fine on their end" but i cant access the net... please help me
Jun 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Weird folder/filenames that will not delete There is a folder on my WD 250 GB Passport Flash drive who's properties show it to be using 157 GB of memory. The Read Only attribute was set, unchecked it. I...
Problem: Folders / files in USB flash drive got named with weird strange characters & those folder / files cannot be copied or deleted.
Reason: Virus infected
Solution:
1. Click on "Computer"
2. Right click on the drive that contains USB flash drive
3. Select "properties"
4. Click on "Tools"
5. Click on "Check Now"
6. Check disc options will appear on screen, put a tick mark in the box in front of Automatically fix file system errors
7. Tick mark in the box in front of Scan for & attempt recovery of bad sectors is not necessary.
8. Click on "Start"
9. Upon finishing of this task, screen will show message "Your device disc was successfully scanned" and bla bla. Close it.
10. After this process the undeletable folder in USB flash drive can be deleted by selecting it & deleting it. The contents of affected folders files cannot be recovered.
After lot of struggle I got this solution on my own by the grace of God.
Sure it will work for others too.
Thanks and regards Raju
Nov 25, 2009 | Western Digital Passport 320GB External...
U tube blank screen no controls most of time
is it just one page or any video , try restarting your browser. Also try getting the latest version of flash.
Mar 22, 2009 | Toshiba Satellite Pro U400-S1001X Notebook
Blue Screen
Use the following steps to replace the missing files when Windows cannot start.
  1. Turn the computer on and place the first recovery disc into the top drive.
  2. After inserting the disc, turn the computer off, wait about ten seconds, and turn the computer on again.
  3. If an HP Recovery screen displays "Press any key to continue...", press the spacebar.
  4. To continue, read the warning screen and click OK.
  5. Click Advanced Options at the top of the screen.
  6. Click Selective Recovery.
  7. Read the Select Files to Restore window that appears.
  8. Type the name of the file. For example, if the error message is MNYUTIL.DLL is linked to missing export MFC42.DLL, type MFC*.DLL.
  9. Click OK. If there is more than one recovery disc, it may be necessary to insert another disc when prompted.
  10. When therecovery process has finished copying files, remove the disc andrestart the computer. If problems, persist it may be necessary toperform a system restore or a non-destructive recovery.
(Note: Click here for information on ordering the recovery CD/DVD sets)
thx.
Oct 08, 2008 | HP Computers & Internet
Error during start of Computer
Hi shyjuu, run a search for the file css.exe (Which may be part of spyware). Once windows has found the file or files delete them. (Double check that they are not being used by a program). If it is, uninstall the program. Run a virus scan on the drive.
Mike
Sep 14, 2008 | Intel Motherboard
EVERY TIME I use my scanner ie scrips errors involving - file:///C:/Program%20Files/HP/Digital%20Imaging/Skins/hp1/sc/scan.htm comes up
Hi I encountered a similiar problem with my HP PSC 2310 printer recently. "file:///C:/Program%20Files/HP/Digital%20Imaging/Skins/hp1/sc/scan.htm". Following are the soultions provided by HP team. Solved mine using solution #1. Hope this is of help :)
Solution 1:
1. Double-click on 'My Computer' icon on the desktop.
2. Double-click on C:
3. Double-click on 'Program Files'.
4. Double-click on 'HP' folder.
5. Double-click on 'Digital Imaging' folder.
6. Double-click on 'Skins' folder.
7. Locate and double-click on 'hp1' folder.
8. Locate, right-click on 'skins.xml' file and select 'Copy'.
9. Click on the 'Back' arrow to go to the 'Skins' folder.
10. Double-click on 'hp2' or 'oov1' folder.
11. In the folder, right-click on any blank space and select 'Paste'.
12. Now restart your computer and check the functionality.
If the issue still persists, please follow solution 2.
Solution 2:
1. Insert the All-in-one software CD in your computer and cancel any installation screen that may appear.
2. Double-click on 'My Computer' icon.
3. Right-click on the CD-ROM drive that contains the software CD and select 'Open'.
4. Double-click on the 'Setup' folder.
5. Double-click on the 'SkinsHP' folder.
6. Right-click on the file 'SkinsHP1.MSI' file and select 'Install'.
7. Again right-click on the file 'SkinsHP1.MSI' file and select 'Repair'.
8. Restart the computer and check the functionality.
Solution 3: Uninstall and reinstall of the software.
1. Insert the CD that came along with the printer.
2. In the CD contents, you will be able to view a folder named "UTIL".
3. Inside the UTIL folder there will be a folder named "CCC".
4. In the CCC folder, among the various files, you will be able to view four files named, Uninstall_L1.bat, Uninstall_L2.bat, Uninstall_L3.bat and Uninstall_L4.bat.
5. First double click on Uninstall_L1.bat file. A black DOS window will open up. This will uninstall the software by Level 1 method. It will take a while until Level 1 uninstallation is complete.
6. Similarly complete level 4 uninstallation by clicking on Uninstall_L2.bat, Uninstall_L3.bat and then in Uninstall_L4.bat.
7. This completes level 4 uninstallation of the software.
8. Now install the software from the CD and check if the issue is resolved.
Cheers,
kypsyche
Jul 10, 2008 | Office Equipment & Supplies
My Finedrive 400 GPS displays the following error message Error Wrong file version Data File az bin 1=aze2 if I manage to get out of that screen the home screen comes on and if I select the...
i would download the latest firmware update from the makers website for your model ok then test it sound like corepted system file so redo it thx nick
Mar 17, 2008 | GPS
System not booting
take windows xp cd and repair from the cd
Sep 01, 2007 | Microsoft Windows XP Professional With...
i-mate PDAL Pocket PC Logo
360 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
