Question about PANDIGITAL Tablets & eReaders
My Evorea Tablet wont turn on from start up Screen
When i turn on the tablet Start up screen comes on but that is as far as it gets. I have pressed thr reset button but that just turns the tablet off.
  • 4 Answers
SOURCE: gateway tablet screen does not respond to pen.
I have a Gateway CX2724 and previously had another Gateway tablet (model I don't remember) but they both look alike and use the same pens. I've had 3 pens and they all periodically stop working. When one stops, I pick up another pen and work with it so that makes me think the problem has more to do with the pen. (They have all died and later come alive.) Sometimes though I can't find the extra pen and have resorted to removing the working pen tip / nib and reinserting it very snugly after wiping off the shaft. The nib is held in merely by friction. You can remove it by pinching its little tip between your fingernails and pulling it straight out. I wipe off the shaft and put it snugly back in. Sometimes I don't take it out, but just press it harder into the pen by pushing it firmly onto a padded surface (so that the tip doesn't deform.) Usually one of these "treatments" works. I know that extra nibs are available with the pen. There must be some reason that the manufacturer thinks they may need to be replaced periodically. But I've never seen any documentation on this.
Posted on Feb 03, 2008
SOURCE: Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Posted on Dec 09, 2008
SOURCE: toshiba M400 tablet wont start
I've had this problem intermittently on my Toshiba M400, and it recently became bad enough that it was failing to start on most attempts, and crashing soon afterwards if I moved it. Prodding the heatsink to change its position may have helped, but this could have been due to chance. It also had a habit of resetting itself when leaning on the left side of the keyboard when typing, but not when using an external keyboard. It's always had occasional crashes under high CPU load, causing the machine to freeze and the fan to go up to maximum. BIOS updates improved this initially, but in recent months it got worse again, especially when using Virtual PC unless hardware virtualisation was disabled.
I've just stripped down the laptop using the guide suggested by thiscomputer at http://www.irisvista.com/tech/laptops/Toshiba-Portege-M400/take-apart-tablet-pc-1.htm (good find!). Many parts are more fragile than in a desktop PC, but otherwise if you're used to taking stuff apart it shouldn't be that big a deal. You'll need a normal and small crosshead screwdriver (jeweller's screwdriver set works fine) and space to lay out the screws in a pattern so you remember where they go - consider making notes.
I fixed two things that could have been a problem: Firstly, a fair amount of dust was blown away with a hairdryer and vacuumed from the heatsink. Secondly, the pink thermal grease that couples the CPU to the copper heat pipe appeared to have all squeezed off the CPU die and had accumulated around the sides, possibly due to the small freedom of movement in the heatsink being repeatedly shaken. The grease was still soft so could be scooped back onto the die with a flat-bladed screwdriver. I also bent the legs of the Y-shaped CPU-to-heatsink retaining clip so that there was a greater downward force on the CPU. I figured this would improve thermal contact, especially if the clip had naturally bent and come loose over time. Removing the CPU itself didn't show any damage, but might have improved the electrical contact when reinserted. Be careful when screwing the Y-shaped retainer back in - because of the springy nature of the legs, if the screwdriver slips the screw will fly across the room and you'll have to hunt for it :-) The other thing to note when reassembling is that the wi-fi on-off switch engages with the lug on the motherboard, if this is wrong you won't be able to move the switch and the actual state will be the opposite of the switch position.
Finally, after I reassembled it still refused to start. I noticed the DVD drive wasn't properly flush with the case, and on removing the DVD drive it started. Close inspection of the drive and laptop connectors revealed a small metal tab had come loose, and the laptop continued to work with this tab removed and the drive reinserted properly. I removed and swapped some memory modules while experimenting with the DVD drive which also had some effect - it's possible that an ill-fitting DVD drive bends the memory above it and affects the contact. It's entirely possible that this was the only problem to begin with, and that playing with the CPU made no difference, so maybe check this first! But whatever it was, happily my m400 seems to be operational again.
Posted on Apr 11, 2009
nashsaint
  • 172 Answers
SOURCE: tablet is frozen will not
Try one of the following:
- Hold the power button for 10 seconds
- Hold the power and up volume for 10 seconds for recovery mode
- Hold the powe and down volume for download mode for 10 seconds
If none of these work then your battery might be completely drained and dead. I suggest you send your contact Samsung Support.
Hope this helps.
Posted on May 07, 2011
TechyDrood
  • 2072 Answers
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Posted on Oct 16, 2011
Tablet will power up but has no touch screen
Defective digitizer (a thin layer of invisible material placed just below the glass that senses the figure) in most touch screen devices.
Five things you should know before trying to fix smartphone or tablet...
Aug 07, 2016 | Tablets & eReaders
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
I have a Chromo 7" tablet, IOS wont start up.
have you tried to press the reset button in back of your tablet.
Jun 26, 2014 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
My craig tablet wont start up
Try factory reset. Press the hidden reset button while powering the unit. This should clear out everything that caused the hangup.
Apr 13, 2014 | Tablets & eReaders
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
I do not have any home buttons when i turn on Evorea Tablet, only white screen, how do I get these buttons to appear?
Hi, I can do the "hard reset" but then my screen gets stuck on the icecream sandwich with the watermarks.
How do I get past this???
Nov 24, 2012 | HP Tablets & eReaders
I have an Evorea Tablet, I power up get a white screen but no home buttons show up, in fact nothing but a white screen
Hello Jachin, if you still have this problem. Try doing a "hard reset"
- Turn off tablet
- Hold down the power and volume "down" key together
- when red text appears select "yes" by holding down power key for 10 secs.
Reformatting shall commence
Please note that this process works on most android tablets.
Hope this helps
Nov 24, 2012 | Android Tablets & eReaders
Tablets & eReaders Logo
Top PANDIGITAL Tablets & eReaders Experts
Colin Stickland
Colin Stickland
castletech
castletech
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
