Question about Starbucks Coffee Makers & Espresso Machines
Barista model 1mp1sp
Won't grind
Need replacement part for Starbucks Barista Blade Grinder! Please help? Went to grind as I usually do but there is apparently a plastic circular part under the blades (I imagine that keeps the blades in...
your best bet is probably to search ebay for a dead one you can strip, cheaper grinders tend not to be supported with parts, personally id recommended throwing it away and getting a better grinder, blade grinders do not give a consistent grind, they are just about acceptable for grinding for a french press but anything else youll be far better off with a burr grinder
May 10, 2011 | Starbucks Barista® Blade Grinder
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
I clean with rice and it grinds coffee beans. Then I have to grind moRE RICE TO GET IT TO GRIND COFFEE AGAIN
Instead of rice, fill container about half full with regular table sugar. Grind that for 10-20 seconds. You should not only get coffee flavored powdered sugar but the sugar will soak up the flavors from your grinder.
Then simply clean as you normally would. Works great!
Mar 19, 2011 | Starbucks Barista Burr Grinder
I have a Barista and, after about a year, is no longer grinds coffee efficiently. Its rather slow. Do I need to get new blades and if so how do I do this and how are they installed.
This model has been recalled by Starbucks and/or Seattle's Best, if that's where you bought it. All you need do is call them and they will send you a new one free of charge.
Here is the website:
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09244.html
No matter where you got it, if you call and just tell them its a Barista they will take care of it. I had an issue with mine also.
The web site gives you the phone number(s) you can call. This is the one I called:
(866) 276-2950
Rose TheRoseFire@gmail.com
btw, if you get a replacement and they don't ask you to send your broken one, I sure could use it. Mine has a piece broken (the plastic piece under the blade that holds the blades in place) and I'd love your broken one so I can replace that piece in mine. Or maybe if you know how to take that piece out, you can send them the rest (they don't care what condition its in).
I'd be willing to pay your shipping! Let me know, thanks!
Jun 20, 2010 | Starbucks Barista® Blade Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Apr 06, 2010 | Starbucks Barista Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
May 14, 2008 | Starbucks Barista Burr Grinder
Coffee Makers & Espresso Machines Logo
121 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
