Question about Kenwood DDX318 Car Video Player
Kenwood ddx318 aux wont play - Kenwood DDX318 Car Video Player
How do i install my alpine cd changer to a kenwood mp528 unit
It is unclear which Alpine CD changer you have and what output connections are available from it.
However your Kenwood unit has Aux input terminals at the back. With appropriate cable connectors you should be able to hook the two up. In the Kenwood you will have to select AUX in menu when playing CD changer. Download user manual for Kenwood from this site.
http://www.kenwoodusa.com/Support/Car_Entertainment/
Search using full model number KDC-MP528
Sep 04, 2014 | Kenwood Car Audio & Video
I have a kenwood ddx318 2 dinn radio and want to hook it up to my overhead DVD player so we can all watch the same movie ! Do I need RCA line ?
Hello! The unit has an "AUX" input that uses typical White, Red and Yellow RCA cables...Red is right...White is left and Yellow is video...Guru...saailer
Jan 20, 2012 | Kenwood Car Audio & Video
I dont understand how to play mp3 player on my kenwood cd player.I have the cord to hook it up to my kenwood radio but i dont know how to get the mp3 to play.
Just plug the cord into the front of the cd player where it says "AUX" and then plug the other end of the cord into the headphone / line out jack on any ipod or mp3 player then select "AUX" instead of CD and the sound will come through the system
Jun 02, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
How do I play my Zune hd through my car speakers, my head unit is a Kenwood excelon KDC-X692
If your Kenwood has an AUX input then you can connect a audio cable from the headphone connector on the Zune to the the AUX input on the Kenwood. Power up the Zune ans set it to music and switch the Kenwood to AUX.
Oct 30, 2010 | Microsoft Zune HD MP3 Player
I can't play my iphone on my kenwood KDC-MP435U
Jennifer, I have the same issue. the problem is that the 2007+ generations of Kenwood receivers are not compatible with the iPhone. You will need to get a 2009+ series in order to use your iPhone with the head unit. I had the same issue with the Kenwood KDC-MP435U in my mustang. I am going to get a newer head unit that supports the iPhone. You cannot do it with the MP435U.
Nov 25, 2009 | Kenwood KDC-MP435U CD Player
GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
Sep 18, 2008 | Kenwood KDC-W3037A CD-receiver,...
When i hook up my ipod to my kenwood kdc mp728 i cant figure out how to play it through the radio
it should be in aux try to press source buton and see if that is an option if not an alternative is to hook it up on the back of the cd player in the audio in or aux or aux 2 using a wire adapter from walmart in the car sterio section
Sep 14, 2008 | Kenwood Car Audio & Video
Playing an Ipod
ya press src until it gets to standby then hold the menu button until it says menu. then press the toggle button down until you see aux and press the toggle to the right to turn it on and be sure to press menu again to set it.
Jan 23, 2008 | Kenwood KDC-MP2035 CD Player
KENWOOD KDC-X491
Have you tried a line noise filter? such as these
hope this helps
thanks for rating
Jan 14, 2008 | Car Audio & Video
Kenwood DDX318 Car Video Player Logo
48 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
