Question about Copystar Cs 3050ci Color Multifunctional System
Copystar Cs 3050ci error code 6150
Has error code c 6150 maintenance fauiler
SOURCE: Copystar CS-1810 Error Code
I have code c620 showing up on my copystar 1810. Anybody have an easy fix so I dont have to take in to shop.
Posted on Jul 01, 2008
  • 58 Answers
SOURCE: C 610 Error Code on a CS-1505 copier
There is no 610 code ,there is 620&630 which are fuser problems.press and hold down these keys,stop/reset key /start key/copy density key.Press stop/reset keyb again. enter U163,press start."CLE"will display.Press start again to clear.Exit the mode with 001.
Posted on Dec 04, 2008
  • 66 Answers
SOURCE: SERVICE ERROR c7980
The errorcode comes up when the waste toner is full.
Unfortunately the waste toner collection is in the process unit.
You will have to replace the whole cartidge.
Posted on Dec 14, 2008
  • 126 Answers
You need to run sim U163 to reset fixing heater problems. Press and hold stop, start, and left exposure key in that order. Release and press stop again. Use zoom keys to enter 163, press start. Exit the mode by entering 001 and start, or power off/on.
Posted on Jan 16, 2009
  • 990 Answers
SOURCE: COPYSTAR CS-1810
Hello sir; "AP" isn't a problem, just let it run for a little while, it will disappear.
Posted on Feb 19, 2009
Paper tray one will not slide back in all the way. Someone pulled the tray right out and now we cannot push it all the way back in. It seems to stop just short of returning all the way to the closed p
Did this happen after a paper jam? Check and make sure you don't have any paper behind the tray. If that is not it, can you pull the paper tray all the way out of the printer? Check the back of the tray assembly. there is a connector, check to see if it looks damaged or broken. If it is broken you also need to check to connector in the printer to see if it is damaged also. If the printer connector is not damaged try a another like tray assembly either from this printer or another printer if you have one available.
Nov 05, 2014 | Copystar CS 3050ci by Kyocera Technology...
My copystar printer is showing error code c6040
This is fuser unit error code, you can try reseting it by running mode 163, if it doesnot work you need to replace the fuser unit.
Mar 14, 2014 | Copystar Office Equipment & Supplies
The printed envelopes come out with wrinkles
you need first to used bypass at the sametime the bypass should be programmed for enelopes so the fuser apply the correct heat.
Oct 10, 2013 | Copystar Cs 3050ci Color Multifunctional...
Error code c410 on cs-2218
If a C410 Error occurs, replace the DP-410 Main PCB Assembly, Ground Wire and Screw.
The PCBs part number is 303HL01018.
Apr 01, 2013 | Copystar Cs-2218/cs-2221/cs-2225 Developer...
Error code C4000 For a Copystar CS2050
it's mean's laser problem need to change it
May 07, 2010 | Copystar CS-2050 All-In-One Printer
Error 3100
turn it off then re do the process
Jun 01, 2009 | Copystar CS-1650 All-In-One Laser Printer
Unrecognizable error code
press 10871087 menu will appear then go to c codes list
Apr 09, 2008 | Copystar CS-2050 All-In-One Printer
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Copystar Cs 3050ci Color Multifunctional System Logo
43 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
