Question about GE WCVH6260F Front Load Washer
CANT FIND BELLOWS FOR GE WASHER - GE WCVH6260F Front Load Washer
    President:
  • 1,214 Answers
You should be able to find any part you need at www.searspartsdirect.com . I just looked to make sure your washer was listed, and it is.
Posted on Jan 23, 2009
Wbvh5300k2ww washer leaking
door gasket or door boot or the door bellows, it can be referred to by any of these 3 names
Nov 11, 2012 | Washing Machines
I was pushing a bulky item into the washer and a spring came loose from around the gasket. where does it go?
If it is the bellows spring thats what holds the big rubber piece( bellows) to the front of the washer. Make sure bellows it fitted in place over front of machine..pull spring over rubber edge at front..If you never did it before have someone help you Good luck...please vote if i helped you thanks
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello; I have a GE Front Load washer and seem
You can't repair the seal, but you can replace it with a new one for under $130 if you do the replacement yourself. You can order it online or from a local appliance shop, as prices vary slightly from place to place. I suggest www.searpartsdirect.com as they usually have the part in stock and you can get it shipped to you anywhere in the US without having to run all around trying to find one locally, etc.
The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washing machine.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer wash tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Here's a line drawing that shows the exploded view of the tub section, with the gasket (item #306). Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20subcomponent%20list
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Sep 20, 2009 | GE WBVH6240F Front Load Washer
Im needing to know how to install the replacement door boot-bellow seal on my front load washing machine. i purchased the seal that i was told is a universal seal due to the original seal part no longer...
Candie, The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20Sub%20Components%20list
Sep 17, 2009 | GE WBVH6240F Front Load Washer
Ripped gasket
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WCVH6260F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090505&backToLink=Return%20to%20Sub%20Components%20list
Sep 16, 2009 | GE Energy Star WCVH6260F Front Load Washer
Broken door gasket how to replace on GE front
You'll need to determine which bellows gasket your washer needs before you undertake the repair. Go to the following link and enter in your washer model number to get the line drawing and parts breakdown.
http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
Click on the "find a part" and enter in your model number
Typically, the tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
You can also call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
Sep 15, 2009 | GE Washing Machines
WASHING MACHINGE NEEDS A NEW DOOR SEAL
Yes, this is a relatively easy repair for the DIY'er to do themselves. With your brand and model number, you can easily determine what the part number is the bellows gasket to replace your damaged one. Typically the gasket costs less than $130 and you'll save at least another $150 in service tech fees by doing it yourself.
Go to www.searspartsdirect.com and click on the Find A Part link and enter in your Model number and it'll bring up a couple of links for your washer. You'll want to click on the "front panel and door" or the "tub and motor" link to see the line drawing and parts list for your washer.
Look for the bellows gasket and that's the part you'll need to fix your washer.
Here's how to undertake the repair:
Sep 11, 2009 | Washing Machines
Tiny piece of rubber seal is torn off- water leaks from front end
You can't really repair the seal, but you can replace it with a new one for under $130 if you do the repair yourself. You can order it online or from a local appliance shop, as prices vary slightly from place to place.
Sep 10, 2009 | GE Energy Star WCVH6260F Front Load Washer
Drum Gasket in GE front load is a design flaw
Since each model can be slightly different and without your particular model number, you might want to confirm that the gasket you have is the correct one for your particular washer.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct bellows gasket.
Here's a line drawing that shows the exploded view of a tub section, with the gasket (item #306). Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
If you enter in your model number, you can see the line drawing for your particular washer and verify you have the correct part.
Sep 06, 2009 | GE Washing Machines
I need help in installing a door bellow on a GE front load washer.
You need to provide the model number as GE has several different versions of the front load washers. But here's the basics for most front load washers.
Basically, you should be able to remove the outer lip of the door bellows by rolling back the edge from the cabinet. Once you done that, slowly go around the gasket until you find the connector. The connector can usually be removed with a small pair of needle nose pliers by simply unhooking the locking hook from the loop side.
Once you've done that you can pull and push the edge of bellows off and into the cabinet and start looking for the hose clamp fastener that holds the other edge of the bellows onto the outer tub. Usually a 1/4 inch or 5/16 nut driver will be needed to loosen the hose clamp and once done, you'll be able to remove the old bellows and the clamps. Pay attention as to the placement of the water inlet, on the bellows, as the new one will need to be place at the same location during the reinstalltion.
Be careful when installing the new bellows, especially when slipping the gasket over the water inlet port, so as not to tear it. Reverse the process and retighten the hose clamp and pull ther outer edge of the bellows over the cabinet edge and reinstall the wire retainer.
Check your work and you should be all set!
Hope you found this very helpful and best regards!
Aug 07, 2009 | Washing Machines
GE WCVH6260F Front Load Washer Logo
42 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
