Question about Sony STR-DE445 Receiver
Right speaker channel low, both front and and back, even the headphones
I got this reciever for free from my brother recnetly and it had been in a box for quite a while. I took it out and hooked up some speakers, and I noticed the right channel on this is super low. I tried a set of headphone to see if it were my speakers, and no fix. I swapped speakers, changed wires, and even tried to reset ( by unplugging for more than an hour) but, still it does the same. Even when I change the speaker balance to +8 on the right channel it stil does not have much sound coming out. I am guessing I need to break it open and start checking the circuits, but I don't know where to start.
  • chris newton Jul 09, 2007
    So, I tried this, no fix. I just need to know which PCB to check I am sure there is possibly an amplifier board, but I cam not sure which one.
  • jimsplace_77 Jan 03, 2009
    i have the exact same problem did you ever find a solution i would really like to fix this it ran good for 4 years then this please help if you can
    Scholar:
  • 150 Answers
There might be a levels adjustment in the setup menu for distance or something, might check that before opening unit up.
Posted on Jul 08, 2007
  • les lake Jul 11, 2007
    If you have low volume on one channel, but it is still working, I would suspect something in the bias circuits or preamp circuits on the main amp board, most of the better units use individual transistors for outputs, they will of course be mounted to a gigantic heat sink.
SOURCE:
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
I am using my speakers connected via the front speakers panel on the back of the machine, I don't know if it matters but they are connected as left and right using "A". So, my left speaker is...
I presume you have proven the channel is dead by trying multiple sources, swapping a different speaker onto it and that the balance control is NOT all the way to one side; headphones don't work either and we're down to proving it's dead before you take it in to a tech, right?
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you
Feb 21, 2011 | Sony STR-DE325 Receiver
My pioneer A-109 amplifier has stopped emitting any sound. power is still being recieved, but no sound from any inputs or sound devices, also no feed back noise. speakers and cables are as should be. any...
If there's not even a hiss from the speakers it may be that you've inadvertently hit the small button underneath the power button which turns the speakers off in favour of the headphones.
Oct 12, 2010 | Pioneer A109 2-Channel Amplifier
I have an mp3 player that i want to hook up to my logitech x-540 speakers but when i do it only plays on the front, or rear speakers depending on which cord i plug it into, is there a way where i can use...
An MP3 player is a stereo device, meaning that it works on two channels - left and right. Therefore a 5.1 speaker system will only play on 2 speakers.
However, if you want to use rear speakers as well, just for the fun of it (you won't get any surround effects, both left speakers will play the left channel, and both right speakers the right channel) you can purchase a "headphone Y-adaptor", that normally allows two people to use two pairs of headphones on the same portable music device.
It has one headphone plug and two headphone sockets in parallel. Plug it into the player, and to the sockets plug the front and rear speaker cables :)
Please come back with a testimonial if helped :)
Dec 22, 2009 | Logitech X-540 Computer Speakers
Hi, I am getting no sound when I connect speakers to the receiver... But the receiver comes on and goes thru all of the menus...
speakers may not be good. volume might not be up high enough. settings may not be right on reciever. i advise you check the speakers first by plugging them into a different stereo. if they don't work, inspect them to make sure they're not blown (cracks in the cone of the speaker). if they do, hook 'em back up and check to make sure there's no headphones plugged in or any settings on the reciever that say speakers or external speakers or anything like that are powered off. hope this helps.
Oct 06, 2009 | Harman Kardon AVR-630 7.1 Channels...
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
Center speaker will not work
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps. 1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - . If that looks okay, 2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact. If this looks okay and the unit is under Warranty, your last test is to: 3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again. If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem. If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Sep 25, 2007 | Televison & Video
Sony STR-DE445 Receiver Logo
256 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
