C++ problem BGI ERROR
Have made a program in c++. My program is running fine, but at the
end of the program there is a error message on the screen:
Bgi Error: Graphics not initialized (use initgraph)
My program shows no error message at compile time or at run time.
What's this bgi error? How can I correct this? I have initialized the graphics hardware by using the initgraph function on the main segment
of my program. I am using Borland Turbo c++ compiler 3.1.
please can anyone provide me a stepwise procedure to solve this
  • tejas_talele Jan 24, 2009
    how to change the path, i am a starter and i don't know much.
    please help me its urgent.what all steps i do?
  • 59 Answers
The most probable reason why the program is not working is because your Turbo C++ BGI Graphics folder is not "c:\\tc\\bgi".
Correct the path and it should work.
If you're sure that your path is correct, press Alt+F5 and paste the error received.
Posted on Jan 23, 2009
Beaumatic BDW10 Stopped before end.No error message
Reset it bgy unpluggin or by shutting off the breaker for five minutes. Then restore power and try again. Let us know
Jun 01, 2013 | Dishwashers
E6 error - incline not responding. Replaced 1A fuse but still not working
I'm getting the same E-6 error while running in program mode although the fuse is fine - and when I recycle power, the program starts fine again and then stops in the middle with the E-6 error. Nor sure what's wrong. Just sandpapered the fuse ends and the connector ends to the fuse socket. We'll see how it goes.
Dec 14, 2010 | Sportsart 6300 Treadmill
How to run digital fortran 6 on windows vista
Here is what I did. Open the DVD (right click and select Open), and then open the X86 folder. Run the Setup.exe file from there and it should install and work fine. I had an error during install near the end, but it seems to have done no harm. I compiled one of my old Fortran apps and it works fine.
Dec 15, 2009 | Compaq Digital Visual Fortran Professional...
Graphics
if you are using turbo c just copy the evgavga some thing lik that name file frm the thae bgi diractory to bin where the real tc recides and enable graphics mode in c options
Sep 06, 2009 | Microsoft Windows XP Professional with...
Graphic problem
Try to reinstall you'r graphic driver. If you don't remember what driver you need, then let a computer program search for it (f.eks Driver Detective, Driver Genius, Driver Agent, etc....)
Jul 29, 2009 | Compaq Computers & Internet
Adobe reader error message
It is possible that somewhere along the line adobe reader became conflicted with an update from something else ect.
First thing you should try is uninstalling adobe reader completely in add/remove programs. Then Install the latest version of adobe reader.
This should put an end to the error messages and restore functionality to normal.
Post back if you need any further help.Thank you for choosing Fixya!
May 27, 2009 | Adobe Acrobat 7.0 for PC
ABOUT TURBO C++
Vista doesn't support full screen mode while operating Turbo C++,
and its also doesn't support graphics(bgi) while operating it.
There are lots of compatibility problems with Vista --
I have Vista Home Premium and have warning when I start VC++ 2005 Express!
I just tried running tc.exe and did not get the warning message you reported.
Although it would only run in the small window.
Your best bet is to download either VC++ 2005 Express or Dev-C++.
They both run full-screen.
Sep 10, 2008 | Computers & Internet
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
ERROR MESSAGE: "Checksum error."
The Checksum error usually indicates a data transmission issue. This may be due to a loose connection, bad wiring, electrical interference (cross-talk), a physical problem with the device itself, or a conflict caused by another software program. * Make sure that the cable attaching the camera to the computer is secure at both ends. * Close down all of the computer's other applications before attempting to download. 1. Press the CTRL, ALT and DELETE keys simultaneously. This will bring up the Close Program Window. 2. Highlight the program that you want to close and select END TASK. The Close Program window closes only one program at a time, so you will have to repeat these steps for each program that you want to close. NOTE: The SYSTRAY and EXPLORER programs should be allowed to run. Do not select End Task for these programs. You will also want to leave any necessary programs running, such as those controlling a wireless mouse or keyboard.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Computers & Internet Logo
638 people viewed this question
David Payne
David Payne
