Question about Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
The flood light stays on and the pump will not work
    New Friend:
Can anyone help? My Simer backup sump pump flood light is on continuously. All the rest of the lights seem to be working fine and the pump looks like it is in working order. When I toggle the lood light button it just gets brighter. tHANKS...SCOTT!
Posted on Jun 25, 2015
Why my car does not pick up speed?I can only travel by 80km per hour,the engine light stays on.
How about your catalytic converter...sounds clogged, need to confirm, and replace...
Oct 30, 2015 | Cars & Trucks
I have fuel but flooding truck i have changed fuel pump ,relay,everything to do with fuel still floods out
Have the cpu read for fault code.Have a manifold pressure and pump pressure test done. Check oxygen sensor for operation
Feb 27, 2013 | Cars & Trucks
Fisher and paykel mw512 stops during washing and beeps. the lights for the short wash and rinse stay on. i can reset it by turning it off at the wall and putting it through a rinse cycle. its intermittent,...
12. (00001100) Phase 1 to 6 - Flood Protection Error
The Motor Controller module has found the water level to be above the flood level
and tried to pump the excess water out. (Under extremely high flow rate conditions
the machine may overfill during the "top-up" routine in agitate.) After pumping for
30 seconds, it has been unable to lower the water level below the flood level. Either
the water valves have stuck on and are letting water in at a flow rate that is higher
than the pump can handle, or the pump is blocked and can't remove the excess
water.
Primary Source: Water Valves.
Action:
If the water valves are on continuously, check that the water valves turn off
mechanically (remove power from machine).
Secondary Source: .Pump system
Action:
Check pump for blockage and drain hose for correct height and kinking
Tertiary Source: Motor Controller module. (Display Module Phase 1)
Action:
If water valves are being driven on electrically, replace Motor Controller
Mar 04, 2012 | Fisher and Paykel Fisher & Paykel Washer
Pump comes on at 2.5 minute intervals. runs 5 seconds, off. does not stay on to pump water out tho well over amount of water there to pump, causing flooding. this is pumps first test and failing...
If the pump doesn't have an intergrated non return or check valve, then one has to fitted on the outlet side in the line to prevent back-flow of water, it sounds like there may also be something blocking the impeller?
Also check the polarity is spinning the pump in the right direction
Mar 07, 2011 | Flotec Electrical Supplies
We can't get the motion on our flood lights to work, what are we doing wrong?our flood lights will go on with the light switch; however, they remain on all the time and will only go off when turned off.
There are different selections on a flood light that you have to adjust. It is possible the you have it in test mode right now and when you flip the switch you are sending powering to the flood and it will stay on because it is in test mode. If it is not in test mode and you have it in the normal operation mode you may have the sensitivity set to high. If there are bushes near, running water, or anything that is moving quite a bit all the time it's going to stay on. Also, depending upon how old the flood is. It may simply need replacing. I would check the first two items and go from there. If you become completely stumped, a good electrician should be able to problem solve this very quickly. I have been on a few service calls where simply the flood was bad and needed to be replaced. I hope this helps.
Jul 12, 2009 | Camping, Backpacking & Hiking
Air conditioner lights come on sometimes and sometimes not. Other interior lights work infrequently. Driver side airbag light stays on. Fuel pump went out, was replaced and went out again , looks like due...
drivers side airbag might work with trick,clean out from under the seat all the rubbish like big mac boxes and coke cans ,then look under the seat and disconnect the cabe for the sensor and clean the contacts in the connector then plug it back in and it should be ok ,do the same with the fuel pump connections on top of the tank ,the dash lights -? well try the earth connection behind the dash ,you sure this vehicle hasnt been in a flood at sometime
Jul 11, 2009 | 1997 Cadillac Catera
Simer A5000 Ace In The Hole Battery Back Up Sump Pump System Logo
285 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Bill Boyd
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
