Question about Hot Tools 120 Tourmaline Ceramic 1" Flat Iron 1163
Hot tools tourmaline flat iron 1163 keeps shutting off
It turns on and heats up but then shuts off
Says error and turns off
my infiniti pro conair turns on & then turns off by giving me an error
Mar 20, 2014 | Conair Infiniti Pro Titanium Tourmaline...
SEDU flat iron won't turn on when i plug it in...
flat iron has large metal foil so change the procdure
Jan 24, 2014 | Sedu Pro Ionic Ceramic Tourmaline Flat...
My Gold N Hot flat iron will not heat up
Suspecct failure of the heating element, use a continuity tester to check the element or the connection to the element as the mains wire is OK. Disconnect the power to test.
Jan 17, 2014 | Gold N Hot Gh2168 Professional Ceramic...
How to stop a flat iron from turning on and off when being used
sounds like a bad connection in the power lead be careful about a possible short hazard ZAP!!! Find a handyman to fix it.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
Sedu flat iron
because it is automatic so it turns on and off after heating at a certain temperature it turns off automatically.
Need instructions on how to use product!
the glove is a heat protective styling glove so you can touch your hair without burning your hand. It is pretty easy to burn yourself because it is so hot. try watching the TiGi videos on YouTube. For a more wavy look I keep my hair around the curler for a couple of seconds and then I run my fingers through.
May 01, 2013 | Helen Of Troy TIGI Bed Head Curli Pops...
Jilbere Titanium Tools hair straightener is not operating correctly. When plugged in and turned on, the red light indicating that the straightener is on lights up, however the plates do not heat up.
I recommend to get a better hair straightener, I bought mine at safrons it's the Karmin G3 Salon Pro with ceramic tourmaline plates to avoid hair damages, it heats up really quick and leave my hair soft, shiny and super straight, hope this helps.
Sep 15, 2011 | Jilbere De Paris Jilbere Titanium Tools...
Gets hot then shuts off
Most flat irons come with a safety setting where as soon as they get to a certain temperature, they shut off (to keep the customer safe). Try turning the setting down to a medium-hot. Also, if it stays on for a long time it will shut off by default to help with accidentally leaving it on. 1. Try turning the heat down 2. Don't let it set for long 3. Try hitting the reset button. Sometimes the settings get shifty, so resetting the device can sort out the problem. 4. If none of the steps work, take it back. There is something wrong with the flat iron, like a short in it.
Apr 08, 2011 | Chi Ceramic 1 inch Flat Iron GF1001USA
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
Hot Tools 120 Tourmaline Ceramic 1" Flat Iron 1163 Logo
23 people viewed this question
Top Hot Tools Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Hot Tools Health and Beauty Expert? Answer questions, earn points and help others
