Replaced lamp in optoma ep1690 but there is not projection
When the projector is turned on the light comes on and the fan but no light is projected
I had the same issue. I replaced the bulb but it would not power up. I held the Power and Menu buttons down for 10 seconds and both TEMP & LAMP light came on and stayed that way. I had to unplug the power. Then I plugged the Power Cable back in and held the Power button & the Source button down for about 10 seconds. The fan started and it came up normally.
Posted on Jan 23, 2014
  • 21 Answers
Hello, many of times this is related to the brighter being turned down and we go about trying to turn up the unit thru the remote and you may need to do this adjustment directly from the panel on the unit.
If this should fail, you may need to unplug the unit and allow it to be off for over 24 hours and this will cause the unit memory to return back to the manufacture's settings and if you still get the same result, consider your lamp may have played out, need to be replace... good luck and I hope thi helps.
Posted on Jan 23, 2009
An Optoma GT750-XL ,
GREEN BLINKING LIGHT stand for power on warming or power off cooling.
Dec 13, 2014 | Optoma GT750-XL - DLP projector - 3D 60403...
Optoma ep 1690, the on/standby led is flashing green but when I try to turn it on the temp and lamp led's flash twice and nothing happens, the on/standby continues to flash green.
The projector lamp life may have exceeded its safe limit, check your instruction manual, sometimes you have to hold the on or off button for 10 seconds to reset this. All manufacturers are different but that may be the problem.
Here is a copy of the manual, I havn't read it, my solution is from experience of other projectors.
Good luck
Aug 04, 2011 | Optoma EP1690 DLP Projector
Purchased 2006. Ceiling mounted. Just stared overheating after approx 10 minutes after last bulb replacement in March of 2010. Floor fan pointed at projector helps. Tried cleaning. Running right side...
Yes, if bulb was low price and was installed in old lamp casing then it is bulb that is not good and creating too much heat that exhaust fan can't throw out to make projector cool enough so temp sensor activates and send over heat signal to system control chip thus projector shuts down.
Please install original lamp that comes with casing to solve this issue.
If lamp was original then check exhaust fan that might be running slowly due to stiffness in bearing so temp sensor finds over temp in projector.
Hope these info will help you.
Dec 18, 2010 | Optoma EP1690 DLP Projector
After being on for a while sometimes 10 minutes, smoetimes 2 hours, the projection loses color and flickers, I can hear a squeeling noise, and eventually shuts down
Mine does the exact same thing, but usually before it overheats and shuts off. This started after I replaced the lamp the third time. I haven't found an outside solution to this, but pointing a floor fan at it to keep it cooler works for me. Did you ever find a resolution?
Sep 09, 2009 | Optoma EP1690 DLP Projector
Optoma ep1690 projector lamp won't come on. Machine starts, fan starts but no lamp. only has about 100hrs used life. Lamp looks perfectly fine but LAMP inicator comes on then goes off. Should I buy a...
reset the lamp timer. if you don't hear a high-pitched whir when you turn it on, the colorwheel is bad. could also be the ballast. worst case, the main board. if it is under warranty, send it in.
Aug 19, 2009 | Office Equipment & Supplies
Light does not come on -- we replaced the bulb--still dark
Sounds like the lamp timer has reached it's limit. In your users manual you will find the proceedure on replacing the lamp and reseting the timer. Once this is done the projector should work.
Jan 08, 2009 | Televison & Video
Hitachi cp-rs55 not working,tic.tic.... noise coming from project
make sure you reset the lamp timer. Manual has the steps. Hitachi Performa CP RS55 3 LCD Projector
if the timer is reset, try cleaning the color wheel. Optoma HD20 Projector Cleaning this video is for an optoma but the color wheel is cleaned the same way in most DLP projectors. Dirty or dusty color wheel sensors cause the projector to shut down and act like its the lamp.
Feb 02, 2018 | Hitachi Performa CP-RS55 Multimedia...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
