Kenmore apartment size washer 326038064 - Washing Machines
Its inside the drum, on the back wall and kidney shaped.
Sep 15, 2013 | Washing Machines
I have kenmore toplopading apartment size. It drains but slowly. How to remove blockage between pump and tub drain?
you might ck the drain hose right at the coupler that hooks to your faucet you will have to cut off that clamp and replace with a small hose clamp.alot of times lint will clog right at the coupler
Mar 11, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore stackable washer/dryer (apartment size) and the washer will shut off when it goes into the spin or rinse cycle. If I turn the control knob to rinse or spin, nothing happens. The washer...
try looking at your pump or you need a cupler that goes on the back sid of the motor price range for the pump is 120 dollars and the cupler is 35 dollars dont quote me on the price of the parts please but that should fix the problem.
Jan 31, 2010 | Kenmore Washing Machines
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Water leaks from bottom
Sounds like your drain hose isn't connected properly to the machine. Look for the base of the hose and see if there's something you can do.
Nov 30, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Model 587784100 My 18inch Kenmore apartment-sized portable dishwasher leaks when running and needs a new main rubber gasket (where the door seals the washer), and a new collar of some sort of white hard...
if you think you can do it then do it. it is normally not any harder than it looks. now because i work there i would say call them :) but you can change those parts fairly easily
Nov 25, 2008 | Kenmore Dishwashers
Object lodged in barrel
Hi Amy, Check this link: http://www.repair-help.com/kb/index.php?article=177 Scroll down and under "ATTACHMENTS" it says: Console-Diagram.gif - Size: 36043 Control_Panel-Diagram.gif - Size: 61802 And you can click on either of those links and it's supposed to show you a picture of how to take your washing machine cabinet apart.
Nov 21, 2006 | Kenmore 44102 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
