Question about Acer Aspire 3000 Notebook
Acer 3500 series wont turn on.
Hi i dont know whats wrong, it was working one day and the next it wont turn on. i just got a new battery for it and it was working perfectly. the only sign of life i can get from it is when i take out the battery and put it back in. for five seconds it sounds like it will boot up but then it makes a beep shuts down. it doesnt even stay on long enough for the screen to turn on. i thought it might be a bad battery so i took it off and plugged it in with the power cord and it still does the same thing. i was just wondering what would be the problem and if its fixable.
  • Cody Chorney
    Cody Chorney Jul 13, 2007
    thanx i changed the battery and it works great. that saved me another 800 bucks :)
    New Friend:
  • 83 Answers
Yes, it sounds like the mother board battery has failed,,,either remove your keyboard and it is a round battery in a plastic holder,,,remove carefully u can buy it at walmart for less than 5 bux replace, re-install keyboad and turn on...good luck
Posted on Jul 09, 2007
SOURCE:
Acer xc-215 blinking power bottom wont turn on
Please remove the battery and try to turn on the computer with the power supply. If the notebook is turned on with power, the fault is from the battery. I await your response, regards.
Feb 08, 2018 | Acer Computers & Internet
Problem with a 2006 ford focus My battery light cam on the other day and i brought it to autozone. Checked the battery and it was bad. Got a new battery put in and checked it again. The battery and...
The charging system on your vehicle is computer controlled . Your vehicle is a rolling computer .The instrument cluster has a microprocessor inside , there is also a body computer ( SJB ) smart junction box , Engine computer etc... they all communicate on a serial data network , C.A.N - controller area network . It's hard to know what's wrong when you don't know how it works . There could be codes stored in the computers , these will not always turn on the check engine light .
Ford Smart Charge System Alternator Not Charging
How to Diagnose Controller Area Network CAN
Mar 25, 2017 | 2006 Ford Focus
Hi ,i have put a after market batterie in my laptop and now at start up it says this is the wrong batterie even tho it does go after it is charged but if i turn it of and reboot screen comes up (wrong...
Hi !
The battery is not compatible with your laptop or maybe defective. As you mention, you purchase this battery and I believe they will replace the battery. Just show them the problem and insist that the battery you purchase is not charging, sure they will replace it.
I hope this help you. Good luck.
Jan 07, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Wont turn back on
frist chack your batteries may be you batteries are not charged frist time you have to charge minimum 6 hrs. if you batteries are rechargeble then chak what is the MAH if you r camera is taking morethen 600 MAH then it will not work u have to go for more then 1200 MAH
then only it will work
Apr 29, 2010 | Kodak EasyShare C913 Digital Camera
Wii balance board wont switch on
i got the wii fit. we hook it up. and it's work. but the next day. it's dont work. i put new battery in it. the light turn on. then shut off by the self. so i dont know what to do? please help us.
Dec 29, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
My Acer Aspire 9300 laptop wont turn on......light indicators are on (motherboard light blinks once, light bulb and battery lights on) but no power to fans so no start up. have had this happen before but...
Very possible that something has short circuited on the motherboard. I would also try re-seating the memory located on the bottom of the laptop(which could be loose explaining the intermittent nature of the issue). On an IBM I once fixed that had the same issue I took out the CMOS battery and battery for one week and then re-installed and that fixed the issue. But good luck to you!
Sep 23, 2009 | Acer Aspire 5315 Notebook
Acer al1916w wont turn on
My living room monitor faced the same issue before.
I called up Acer, and they fixed the power LCD board in the monitor.
Do not buy a new one yet, unless the warranty is over.
Jan 01, 2009 | Acer AL1916W 19" LCD Monitor
Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Apr 09, 2008 | Computers & Internet
remove the battery and see it the power comes on, if so bad battery, check the connector where the power plugs into the laptop, sometime this breaks or has a cold solder joint, you can test this by wiggling and looking to see if the power lights up. last and worst case is a bad main board.
Jan 07, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 3000 Notebook Logo
101 people viewed this question
Ekse
Alun Cox
