Question about Bosch Tassimo TAS4011GB Coffee Maker
My Tassimo Bosch smells like burnt rubber.
When i make a cup of coffee it tastes and smells like burnt rubber
4 Suggested Answers
SOURCE: Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
Posted on Nov 20, 2009
SOURCE: manual instructions bosch tassimo coffee maker
hi, this morning I was making a capuccino, and the first part was fine, the expresso was fine, I waited for the light to change colors, open the lid, put disc with the cream in the machine and the green light won't come on, only the yellow on the left hand side and is not working<br /><br />
Posted on Aug 23, 2010
  • 5103 Answers
SOURCE: how much bicarb of soda do i use to descale my bosch tassimo
Sodium bicarbonate is not a descaling product. It makes a nice minimally abrasive cleaning agent when mixed as a paste. Sodium ions will exchange with calcium in a water softener when the calcium is dissolved in water. Once the calcium salt (calcium carbonate) forms, it doesn't go back into solution in a neutral or basic environment. A bicarbonate solution will be basic.
Descaling requires an acid. The Tassimo products say "Do not use vinegar" (acetic acid). I suspect they use citric acid in their descaling product. You can try the lemon-flavored Kool-aid (the version packaged in the envelopes that needs a sweetener added when it's a drink). Mix 1 tablespoon of the powder in 1 pint of water. However, you'll need to make more than a pint of the solution since you need 500 ml of liquid per cleaning cycle. (1 pint is ~473 ml.)
I hope this helps.
Posted on Apr 25, 2012
Bosch tassimo coffee maker What is the yellow disc for where you place the coffee pod? Also what is the digital piece on the lid for? If for size of coffee cup fill , how do you adjust it?????
Hi The yellow disk is used when cleaning the coffee machine and the size for cups is usually on the tassimo pack at the back.
The "digital piece" is a bar code for the discs.Hope that helps? ps,
Go to Tassimo site for info
Feb 05, 2017 | Bosch Coffee Makers & Espresso Machines
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Bosch Tassimo TAS4513UC 1-Cup Coffee Maker manual
I looked up your problem and found the same one was answered previously on fixya. I have copied and pasted the previous answer here for you. Good luck and I hope you have a great day!
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Mar 25, 2014 | Bosch Tassimo TAS4513UC 1-Cup Coffee Maker
Not getting full cups of coffee for normal size
According to the manual, don't use vinegar or products containing vnegar to descale.
Sep 01, 2012 | Bosch Tassimo TAS1000UC 1-Cup Coffee Maker
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
Bosch Tassimo TAS1000UC/01 Water leaking under the machine
check and see if there is a rubber seal under neath if there is replace the rubber probably the rubber crystalized.good luck
Sep 25, 2011 | Braun Tassimo Espresso Machine/Coffee...
Hi,when my tassimo finishes filling the cup,it
For a Braun machine, unfortunately this is quite normal as it's part of the "purge" once it has finished brewing.
The new Bosch machines do not do this and finish their cycle with a steam purge instead.
Mar 25, 2010 | Braun Tassimo Espresso Machine/Coffee...
Tassimo
Have you tried using bottled water? I had the same problem and found that Spring water tasted the best.
Jan 14, 2008 | Braun Tassimo Espresso Machine/Coffee...
Leaky Tassemo coffee maker
i think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
Feb 03, 2007 | Braun Tassimo Espresso Machine/Coffee...
Bosch Tassimo TAS4011GB Coffee Maker Logo
503 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
