Question about Jenn-Air 35 in. JEC9536ADS Electric Cooktop
JEC9536 2 right side burners will not work
When you turn the know for the either one of the 2 right side burners there is no heat, no sound...nothing. Whe we called for service they did not come out but knew what it was without even looking at it. I thought maybe I could find out what the problem is and save myself $300 bucks.
Thanks
  • clutch1989 Jan 23, 2009
    The cooktop is electric but when you turn on any of the elements you will immediatley hear the fan or a small "hummm" and then the red glow. When you turn on the two right knobs (by right it is from me standing in front of the range) there is nothing. The middle and two left work fine. It is only 2 years old so I can't imagine what it would be but the service tech did without looking at it just by our explanation.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    because you say sound,im thinking its gas and your not hearing the spark ignitor's clicking.if you lit a match and held it to you burner and then turn knob on you should have a flame.jenair's has removable crartiages so to assume its the spark moduel may not serve best.there is an electrode that exstends from the cartiage into the range that could also have some failed points.when you turn your knob too lite burnner there's also a switch on each burner valve.but if one was bad it would not stop both,so it has tobe somthing they have in common.do you have two cartiages ,if yes switch them that would narrow it down abit.if works then problem in your cartriage.if not the in the range like spark moduel,wiring!
    President:
  • 1,214 Answers
Sounds like a broken wire, but if the service people already knew what was wrong, you should be bale to type in the Make and Model number into a Google search and find more information about it.
Maybe SearsPartsDirect will have a wiring diagram that you can look at to help diagnose the problem.
Posted on Jan 23, 2009
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
Aug 30, 2014 | Cooktops
GE Profile mod. PP975bM3BB all lights work Burner will not heat
You have lost half of the circuit in the breaker, the lights work on one side of it but the burners need both sides of a 220 volt circuit. I would have the breaker tested first, and if it is good, look for a fuse, relay, breaker in the back of the stove. Hope this helps.
Mar 06, 2012 | GE Profile 36" Electric Induction Cooktop...
Ingiter will either fail to start burner or won't quit clicking on the 1% of the times it does start up the burner
Hi look for adjustments to the lighter and also there should be a sensor tat sees the fire , this sesor allows the main gas to turn on, but only if it feels the heat , kind of like a thermocouple , if you think about about any type problem like this: what is it not doing ? then think what could cause this >/? if you go about any repair this way there is nothing you can't fix unless you need a part !
Dec 05, 2011 | Jenn-Air JGC8430 Gas Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
Two burners wont ignite
Sounds like the electric sending unit for the right burners is not working. Do you hear the cliking noise on the right side when you turn the knob to LITE? If not then you need to replace the electric sending unit, they are located under the knobs, they are a smal square box that goes on the switch valve rod, they have tow wires on the side, just unplug and lift, and look for greasse or anything that might interrup contact, you might be able to use the same ones, or just replace with new ones....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 14, 2008 | Cooktops
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
It is not a GE but it is a Jenn-air
It's either a bad spark module or switch.
Nov 17, 2007 | GE 36 in. JGP628 Gas Cooktop
Jenn-Air 35 in. JEC9536ADS Electric Cooktop Logo
229 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
