Question about Toshiba Satellite A205-S4617 Notebook
Connecting notebook to tv with s-video
When I connect my Toshiba Satellite notebook to the tv via s-video all I am seeing on the tv screen is the Windows desktop background picture but no icons or other data from the notebook.
I have set up toe tv as a secondary display and set the resolution to 800/600.
  • jmccr8 Jan 23, 2009
    It worked! Thanks for your help.
    Master:
  • 413 Answers
Secondary display is like a blank desktop to show open windows or programs you have to drag them off your desktop to the left or right, whichever you set the TV to. to fix this look for a button that has two monitors on it on the F-row. F1,F2,etc. Hold down the Fn key and push the display function key at the same time. You might have to push the display button a couple times.
Posted on Jan 23, 2009
  • Dan rogers
    Dan rogers Jan 23, 2009
    I'm glad i could help thanks for the rating'
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
I don't know what cable to get to connect my Toshiba satellite L305 to my TV.
Some use USB to connect pc to tv. Others use a ps/2 type with the pins in it to connect. Once they are connected, go to your main window screen, right click, go to properties, go to display. You will see a box #1 and a box #2. You will need to click and drag box #2 to the left side of box #1 and then click apply, then ok. Now you should see your screen on your tv
Dec 31, 2010 | Toshiba Satellite L305-S5877 Notebook
CAN I HOOK MY TOSHIBA SATELLITE P15 S420 LAPTOP UP TO MY LCD TV?
Well bud it actualy depends on the TV that you are using.
Some TV's do not accept the signal form the NB.
try to use a different TV and after connecting it to ur TV press and hold on the FN key and tap on F5 to transfer the display to the TV.
Aug 21, 2009 | Toshiba Satellite P15-S420 Notebook
Can i connect my laptop to the tv?
Yes there is a way to connect the laptop to the TV via VGA output. You can easily connect most of the laptops to TV via VGA and your notebook is fine for that purpose as well.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Toshiba Satellite L305-S5933 Notebook
Connecting Toshiba Satellite A105-S2071 to TV with S-video/RCA
after hooking the pc to the tv make sure the tv is set to the correct input, hit alt+f5.
Aug 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Green screen on Toshiba 34N9UXE
you can have a bad CRT, a bad chroma module, either one can show the symptoms you are describing. You will need a TV repair tech for the right diagnosis.
Jun 02, 2009 | Toshiba Satellite A105 Notebook
Phillips 40" lcd Connect my pc via DVI
This most likely means that your lcd doesn't support the resolution that your laptop is displaying.
Feb 23, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
follows:
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Connecting to Pioneer pdp 4270xd
  1. Go into Start->Control Panel
  2. Open up Display Properties
  3. Navigate to the last tab
  4. Enable your second monitor from this tab.
You can also change your external monitor settings if you have the nVidia graphics chip by right-clicking on your desktop and selecting the nVidia Displays Manager.
Mar 26, 2008 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
